Just a girl that dunno lol
Rep Power: 0 Just a girl that dunno lol
So I have a 98 EK and lately it's died on me. Ill be driving (obvi) and the check engine light will turn on and then the battery and oil light comes on , it gives me enough time to pull over then shuts down , the steering locks. It takes about 10 to 30 minutes to start back up. The Radio , lights and everything works. I don't know what the f is wrong with it. I've put a scanner to it and no code has came up. Now my check engine light is on and it's p1456 which is something to do with the fuel. Girl problems Hahaa.
Rep Power: 210 Re: Just a girl that dunno lol
P1456 is Evaporative Emission Control System leak (fuel tank area). It could any number of things. You need to find a service manual and diagnose for P1456. You also need a vacuum gauge.
P1456 is not the reason it dies.
I'd be checking for loss of spark or fuel before chasing that code.
30 minutes actually sounds like an igniter problem. I'd be doing some tests while it is dead. If it is a dying igniter, it will probably be completely kaput soon.
Rep Power: 0 Re: Just a girl that dunno lol
Yea I know the code isn't the reason , the code came up months after. I'm just worried about why it dies , I wish it was though because when it died the check engine light came on but it doesn't save the code.
1 Post
i dont understand y the steering wheel locks up? this is a feature that happens when the key is turn backwards and a pin in your steering colum locks,hmmm, wierd the engine light and oil light come on,does the other lights come on too? as if u were starting it? what i mean is is it the same light
s on the dash coming up like when u start it? oil light comes on when oil pressure drops below a certain psi, bad oil pump?plug pick up screen? maybe something in the pan floating and getting caught once and awhile?. loose ecu in pass kick panel? .sorry im thinking of so many scenerios...
There is no code to save, it wasn't a fault of something the computer can set codes for or monitors.
Normal for the situation.
Someone needs to figure out whether spark or fuel is missing when it quits. (It may be easier to figure out once it completely dies.)
The steering does not lock up, it just gets harder to turn.
The car can still be steered, just takes a little more effort (muscles).
when I try to start it up the oil , battery and check engine light come on
After the engine runs they should stay off. Except for the check engine light with the p1456 code.
ricer_em2
05-11-2016 08:09 PM
Skunkone
09-24-2015 04:38 PM
