96 civic with check engine, abs, & srs lights on.
Rep Power: 0 96 civic with check engine, abs, & srs lights on.
Hi guys my civic has all the warning lights on, what's the best way to correct the problems?
#1 check engine light, scanner reads codes p0325 knock sensor, THE EXHAUST MANIFOLD IS SEVERELY CRACKED, could this be causing the knock code? also code p0135 o2 heater circuit, I have replaced the o2 sensor but haven't checked it the code came back, third code was p1337 ignition misfire crank speed sensor.
#2 ABS light is on, I have no clue how to extract codes if any for this function, can any one help.
#3 SRS light is also on, again no clue how to diagnose the issue.
I will be replacing the cracked exhaust manifold asap, just want some advice from those most familiar with these cars.
Xuhme
21
08-07-2023 03:40 PM
dooner24
04-14-2015 07:51 PM
bahena08
04-11-2015 05:09 PM
