need help setting crossover
Old Apr 24, 2003
EnProceso's Avatar
i read my amps manual today and it said for driving a pair of subwoofers (which i am), set the amp on "low pass" and it will filter out high frequencies and only send low notes. so i did but then all i heard was treble coming from my speakers and i couldnt even hear my subs. do i need to adjust the crossover freq.? i only want the low notes so the subs hit harder, before i had the amp set on "fullpass" which lets in high and low freq. and i dont like having high note bass (if that make any sense). so how should i set up my amp?
Old Apr 24, 2003
mohawkboom's Avatar
Okay maybe your amp company reverse the part..try setting it to high pass and see what happens.. you shouldnt get any vocals or other sound from your sub.. also turn the frew **** to where it reads about 60-80hz or so.. that's a good start.. turn the **** slowly in either direction untill it sounds good to you.
GolNat
Nov 27, 2018 03:32 PM
JMKendrick
Sep 16, 2015 06:17 PM
Wheela
Wheels and Tires
Sep 7, 2015 02:14 AM
JohnDay
Wheels and Tires
Sep 6, 2015 06:42 PM
