pyramid component speakers?
Old May 6, 2002
PK2K1's Avatar
PK2K1 is an unknown quantity at this point
alright, i know pyramid has a bad rep, but i was at the flea market and i saw these component speakers 6 1/2" CK657.. they say 400 watts rate power.. and they were only $70 canadian so i took the risk. are these any good? or should i try to return them or sell them to someone else?
Old May 6, 2002
Subrage's Avatar
Subrage is an unknown quantity at this point
how much us is that if its more than $20 you got screwed. pyramid sells $hitty stuff not even worth buying.
the 400 watts ratted power is for another pyramid amp. if you stuck a quality 75 watt amp on those they would fry. i would try and take them back.
just my $.02
Old May 8, 2002
mohawkboom's Avatar
Really not worth it... Pyramid 400 watts is ILS(If Lightning Strikes) Pyramids 400Wrmsx4 amps have been bench tested at 63Wrmsx4 at over 13% THD.. The Speakers have a 3/8" Voice coil.. that's the same size as the OEM speaker has..it's just numbers they slap on there without Merit..and in the fine print you'll see..(Can handle 400 watts peak for a 2 second perriod, using a 3khz unclipped sinewave)
Old May 8, 2002
PK2K1's Avatar
thanks guys.... well i'm gonna return them.. they have a no refund policy but i guess i'll exchange them and a bit of money and pick up a decent used amp.
how are lanzar component kits? i'm looking into a couple of the models
VPRO6.1 6.5" Two-Way Custom Component System
CDM6C 6.5" 2-Way Cadmium Component Kit
NEO6C Neo 6" Component system
www.lanzar.com any info is appreciated.
Old May 8, 2002
Subrage's Avatar
pyramid bought out lanzar so all lanzar is pretty much crap aswell. if you want a good set of components with out really breaking the bank go to sounddomain.com and look for the crystals.
Mad Dog Tannen
Oct 19, 2016 08:12 PM
UltraHDGames
Jun 8, 2016 05:16 PM
Gsxtacy
Sep 12, 2015 01:09 AM
Mad Dog Tannen
Sep 12, 2015 12:48 AM
redcloud
Sep 7, 2015 01:45 PM
