Please Help rear speakers wont fit
Rep Power: 0 Please Help rear speakers wont fit
i am replacing the rear speakers in my 04 civic coupe and the speakers i bought when i place them in the magnets hits the bars underneath. its the bars for the trunk to stay open. and when i try to open my trunk them bars hit the magnets. any help would be great. thanks
Rep Power: 232 Re: Please Help rear speakers wont fit
aaahhhhh try taking the plastic panel off and load the speaker from the top . maybe evan cut some wood spacers or return the speakers for shallower ones
1 Post
Rep Power: 306 Re: Please Help rear speakers wont fit
fold your seats down and check to see if they clear with the trunk closed. My alpine type S's have rubbed for years and i havent had any problems, since they clear when the trunk is closed.
Rep Power: 0 Re: Please Help rear speakers wont fit
i have took all my panels out of the car (installed dynamat threw out). when i loaded them from the top they stuck up about 1/4 inch wit the trunk open. ill try to put them in with the trunk closed and see if i can still open my trunk. Kcari if i remove the bars the trunk wont stay up when open. that is the tensenor for the trunk lid. I may do this since i dont use my trunk very often anyway after i finish my system i wont have much trunk space anyway.
1 Post
Rep Power: 293 Re: Please Help rear speakers wont fit
you need spacers... they lift the speaker some so the magnet clears. You will probably have to make them yourself out of wood or something, as I do not know if Metra makes one for the rears...they do however make one for the front as the hole is kinda weird...
Rep Power: 787 Re: Please Help rear speakers wont fit
you may want to switch from the torsion bars to the trunk shocks/lift supports that are used when a spoiler is installed.
You Stay Classy, San Diego
i agree with gearbox. If you just make trunk shocks it will solve the problem. Also i was wondering wont you lose some sound quality if you put spacers in because the sound will go out the sides of the speaker. Im picturing spacers as just going at a few points and their being a gap all around the rest of the speaker. Wouldnt that change the sound of them and make them sound worse?
Causemo
07-04-2015 07:11 AM
