Amp problem
Old Nov 24, 2006
GOTSPRINGROLLS's Avatar
Super Member
GOTSPRINGROLLS is an unknown quantity at this point
Amp problem
Ok guys i really need your help with this one. I was listening to music and then I heard static and then nothing. The amps turned off. I've checked the brain to the monitor and the remote wire with a volt meter and everything is good until it's hooked up to the amps. I'm running an Alpine MRD-500 and a MRV-F340. When I turn the car on, the amps turn on for a second and then shut off. Does anyone know what the heck is going on?
Old Nov 24, 2006
christmaspie's Avatar
christmaspie is a glorious beacon of lightchristmaspie is a glorious beacon of lightchristmaspie is a glorious beacon of lightchristmaspie is a glorious beacon of lightchristmaspie is a glorious beacon of lightchristmaspie is a glorious beacon of light
If I'm hearing you correctly you're losing voltage to the remote turn on inputs on both of your amplifiers. Installing a relay will probably fix your prob if that's the case.
roverben
Jan 21, 2019 05:16 PM
numbersguy
Electrical DIY
Sep 15, 2018 11:24 PM
jackoncruzpr
May 24, 2015 12:24 AM
0100010
Dec 1, 2001 03:27 PM
PimpBot5000
Nov 26, 2001 07:15 PM
