Wiring question
Wiring question
Hi, everybody
I finally got to installing my sub and I have two questions ( i know, i know i read all the stickies
1. How do I figure the power wire (i got stock stereo still )
2. Does it mean i can just connect to any metal part without running the wire to the engine bay?
sorry for nubie questions, gotta get it right
1. remote turn-on wire from the deck to the amp so the amp turns on when the deck does (it even says remote on/off next to it
2. attach to any bare metal surface on the chassis.
).2. attach to any bare metal surface on the chassis.
btw what gauge wire i should use for powerwire and speakerwire?
does it matter if gauge rating is a little higher than needed?
It all depends on what your total RMS is and how far you are running it. Here is a link with some recommended power sizes
http://www.the12volt.com/info/recwirsz.asp
for speaker wire usually you are ok with 14/16 for speakers and 12 for subs.
Well seeing as how you're running a factory deck you won't have a remote turn on wire. The best thing to do in this situation is to hook it up to accessory... assuming you have a 7th gen civic the accessory wire will be yellow with a red stripe.
Originally Posted by coop
hexed - how are you connecting the stock receiver to your amp?
juror
Jun 9, 2015 02:15 PM
werdnahall
May 17, 2015 11:37 AM
pincookie1
May 4, 2015 12:22 PM
