| maybe your amps aren't working? maybe the RCA connection got loose on your head unit? it could be a number of things. if you can, try hooking your amps to someone else's subs. if it works then you know for sure that it's your subs. if it doesn't work then... well atleast you know it's not the subs that are messed up. |
