problem with sub and amp
i have a alpine mrp-m350 amp and a alpine swr-1241 sub and every time i turn it up a little bit they cut out. when it cuts out if i turn off the HU and then back on as soon as i turn it off, it starts working again but shuts off at the same point. this is my first set up so i don't really know if that is normal or what? do i need a bigger guage kit? right now the guage is at 300w. also, this all happened when it started getting hot outside. but it still does it in the middle of the night when it is cold as hell. is my amp or sub fried? thanks
check the amp when it shuts off, is the amp hot?
always check wiring again. check settings on the amp, make sure you don't have bass boost and gain cranked to the point where you're overworking the amp, or clipping it bad
check settings on your HU. cranking bass on both amp and HU beyond what it can do can make it clip pretty quick
ALso, check to see if your Amp is still getting power when it cuts out, and if it has Protect light, see if it's in protect mode, maybe your wired wrong and the amp can't handle that impedence load.
could simply be the ground on the HU or amp. happened to me before, ground on amp was loose, kept shutting off at high volumes.
when you turn it up and it cuts off, if you turn the volume down, does it continue playing? or does it completely shut off when you turn it up, like go into protection mode?
the music keeps playing (even when i put the volume down) but the sub cuts out, so i turn it off and then back on. i haven't checked if it goes into protection mode. when the light turns red, right? it is wired at 2ohm, maybe i should bring it down to 4? i don't know what to do. i really just want to buy a bigger gauge kit to see what happens but if it doesn't work i'll be wasting money. its been working great since september. up until this past month or so its been a bitch to me. thanks. any more suggetions?????
I have an M350 in my truck. It runs w/ the gain full on at 2 ohms w/o any problems. I have had it over a year now. I'd say you might have a loose connection. Double check all your connections. And yes, see if the protection light is coming on. That will help us diagnose the problem.
i checked today at school, no light changed, it remained blue. i was thinking about getting a new guage wire i just don't wanna waste money. because if its the sub i can replace that, but not both sub and guage. i hear a low *pop* right when the sub cuts out. its pissing me off though. do you think the sub is too weak now? i bumped lil' john and the east side boys hella loud in my car for hella long about 1 1/2 months ago with no problems. now i can't even bump the black album...
before you spend any money...that's the alpine type-r sub...i believe that is the dvc...you might have the subwoofer itself wired incorrectly...if you have it wired in parrallel...i believe it would do what you are explaining....try wiring it in series instead...
If i'm understanding your question correctly...actually i don't understand the question at all....by his description, it sounds like what happened to me when i first installed the mrd-m500...the load was wrong so it went into the protection mode....so yes it would go into protection mode if the load was wrong...cause if he has it wired so the sub is trying to pull 1 ohm from a 2 ohm amp...it will cut out...and if this is what the amp looks like....the one that was stated in the first post...this is the mrp-m350.....
Then maybe its the problem that would come up on the digital amps as E-3...Error 3 which is an overcurrent....which would still mean your trying to get something similar to 1 ohm out of a 2 ohm stable amp....i would just try rewiring the sub in series rather than parallel...that sounds like it would fix it...
well, i'm just running one amp and one sub. its been the same set up since september and has always hit hard. i haven't even changed the gian or anything like that since i installed it since september. i'm also thinking i need a new ground wire and power wire because it might be sucking too much power like GSXR said earlier. i think that becasue when i was hitting it hard a while ago it hit so hard it blew my fuses on my neons, HU, and alarm. i think i'll start little by little, like getting a bigger ground, then if that doesn't work power, and so on and so on. thanks for the help guys, i'll try something tomorow. maybe stop by somewhere and get a 4g ground or something and post if anything changes. oh, i don't even remember how i wired my sub, but i don't think it was parallel
kalipnoi....some of that info would have been good if said earlier....it's def a connection somewhere then...i would check behind your deck if i were you...or even the car fuse for the system...
For what its worth, I have 4 guage on mine.
For wire etc, you can't beat the price of the 4 guage wiring kit from Walmart. Its name brand (Scosche) and costs about $25, can't get any cheaper than that.
Honestly though, I still think its a loose connection somewhere.
i went over to a car audio shop around where i live and i had them swap out my sub for another just to test to see if it was a sub problem. when he hooked it up he played it and it cut out again. he said it might be the amp but i have to wait till this weekend so i can borrow my friends because i didn't want to be at the shop any longer. i don't know though, it seems like the guy was just guessing. damn, i'm pissed...
jackoncruzpr
May 24, 2015 12:24 AM
0100010
Dec 1, 2001 03:27 PM
PimpBot5000
Nov 26, 2001 07:15 PM
