amp/wiring problem
Old Oct 14, 2003
EnProceso's Avatar
amp/wiring problem
i seem to be having a problem with my amp or with the wiring. at any given moment my subs will cut off for a minute or so and then come back on. it will do this numerous times during a 15 minute drive. at first i thought it was at the fuse holder, cuz when it cuts off, i'll pop my hold wiggle the fuseholder and it will come back on, so i redid the connections to make sure they were solid but it still happens. so i'm not sure if something is loose or somethings just wrong, any ideas?
Old Oct 14, 2003
alex053's Avatar
loose ground or remote? if you can see the amp, check if the power light stays on.
Old Oct 15, 2003
4Saris's Avatar
4Saris is an unknown quantity at this point
Ground or possibly it goes into protection mode from the speaker wires touching each other.
Old Oct 15, 2003
EnProceso's Avatar
i thought of this, but its hard to see the amp when its mounted to the back of the back seat behind the driverside, even with the seat folded all the way down. i'll have to drive around and have someone else look at it (it never seems to happen when i'm parked!). good idea about checking the ground, i'll have to check that out, also recheck the speaker wire.
Old Oct 15, 2003
Braydogg's Avatar
Braydogg is an unknown quantity at this point
18 sec......what kind of subs you pushin and what amp you have.....I was having the same problem with my kenwood pushing one JL dub 6......so I brought a new amp thats 2 ohm stable......no problems after that and im pushin 2 now.....it may be the amp ....it might cant handle the sub stability.
Old Oct 15, 2003
4Saris's Avatar
Braydogg brings up a good point...........
Can you diagram how you are wiring the subs, are they in series, parallel, bridged, one to each channel? Braydogg might be right, you might have the ohm load beyond what the amp is capable of. If you bridge two 4 ohm subs, that is generally too much for the amp as it would be 2 ohms, but in bridged I think the amp sees it as 1 ohm.
Old Oct 15, 2003
nickq's Avatar
nickq is an unknown quantity at this point
Yes it sounds like the ohm load is too low for the amp.
Old Oct 16, 2003
EnProceso's Avatar
its a 2ohm stable amp, and they are wired to the subs in parallel. i had this setup for a year now and its been fine except for this past couple weeks, i know this is not the source of the problem. i saw the amp when the subs cut off and it wasnt even in "protection" mode so no power is getting to it. it must be the fuse holder, something has to be loose to it. but i redid the connections TWICE now. mayeb should just get a new one?
Old Oct 16, 2003
nickq's Avatar
You say that it was not in protect. Did the power just shut off or was the power still on and the subs just quit?
Old Oct 16, 2003
EnProceso's Avatar
all power to the amp was off, so this makes me think its the fuse/fuse holder...thats the only break in the power from the battery to the amp and like i said when i jiggled it around the amp would come back on. but what i dont understand is i redid the connections twice and it still does this. could it be a bad fuse or fuse holder?
Old Oct 17, 2003
nickq's Avatar
Okay so you are talking about the fuse on the wire from the battery? Or the fuse in the amp? If it is the one from the battery then I would think about replacing that just to see if that is it. If it is the one that is in the amp then I would think that It needs to re-soldered.
Old Oct 18, 2003
EnProceso's Avatar
just in case anyone was following this thread, i replaced the fuse in the fuse holder, when i took it out it had some frizzle frazzle marks on it. i'm not sure what its from or how they got there but when i changed it, it works perfect.
Old Oct 18, 2003
jwalker87's Avatar
Bodacious Member
jwalker87 is an unknown quantity at this point
yaaaay
Old Oct 21, 2003
nickq's Avatar
Hey that is good to hear. The sparks were probably arcing.
Diznavis
Jan 25, 2002 11:25 AM
TeamStylesRacing
Jan 20, 2002 08:38 PM
delacampos
Transmission
Jan 2, 2002 02:06 PM
Speedy
Idle Issues
Dec 14, 2001 09:04 AM
Flatlander
Nov 16, 2001 05:38 PM
