Alpine settings
Old Aug 24, 2003
xmeeksx's Avatar
xmeeksx is an unknown quantity at this point
Question Alpine settings
i have a cda-9813 and it is by far the most complicated HU ive had. i dont know anything about setting the crossover points and time correction. anyone have any idea how to make it sound so that i have good treble upfront and heavy bass in the back. i dont even know how to adjust the bass and treble because i dont know which frequency is for which. any help would be appreciated. i have pioneer rev components up front and pioneer 6x9 5ways in the back if that helps. i tried using the i-personalize site but its very complicated and i dont know what the heck they're talking about. anyone have the numbers to put in or the file that they downloaded from the site to burn to a CD? what should i set the crossovers to? anyways..thanks in advance for any help
Old Aug 24, 2003
evilone's Avatar
The Nightraid crew - Sensible Ownage
evilone is a jewel in the roughevilone is a jewel in the roughevilone is a jewel in the roughevilone is a jewel in the rough
higher frequencies-treble
low frequencies-bass
I'll see what I can come up with....
TWITCH
Old Aug 24, 2003
xmeeksx's Avatar
hey evilone..do you have the cda-9813 as well?
Old Aug 24, 2003
evilone's Avatar
Nope, I just tried to play it by ear....to confusing for me, considering I don't have any idea where to start, and couldn't do time correction since I don't know cabin size or anything, and didn't have basic stuff to start with. I just set the sub crossover to 20Hz, rear point to 50Hz, and front point to 125Hz. Try it if you want, but I don't know what it'll sound like.
Old Aug 24, 2003
xmeeksx's Avatar
anyone else have any ideas?
Old Aug 24, 2003
Litespeed's Avatar
Litespeed is an unknown quantity at this point
When you're going through your crossover settings, it should say HPF (high pass filter) or something like that for your front and rear speakers. Just set the frequencies for the front higher than the rears. One of the options for your filters may also say "though" meaning that the HU will allow all frequencies to go to your speakers. That would probably be the one you want for your rears. Look through your owners manual. It will tell you how to adjust your settings. If you don't have the manual you can go to www.alpine1.com and download it.
Old Aug 25, 2003
mattymatt's Avatar
mattymatt is an unknown quantity at this point
I could give you the timing correction because I have the 9815 and I'm sure they're the same but it really depends on where you are sitting in the car because if you sit way back or if you sit closer to the steering wheel then the settings will be different. So I suggest you do it yourself. All you have to do is measure the distance from each speaker to where your head would be and then put those measurements in the I-Personolize section of the website. It's very easy. Just register, put in the type of HU you have and go to timing correction and it will explain everything.
Old Aug 25, 2003
mattymatt's Avatar
Also make sure your computer accepts cookies or they won't let you on I-Personalize.
Old Aug 25, 2003
xmeeksx's Avatar
what settings do you guys have for you're crossover?
Old Aug 26, 2003
mattymatt's Avatar
I didn't set mine yet.
Old Aug 27, 2003
custom2k1's Avatar
custom2k1 is an unknown quantity at this point
My crossovers are set at 80 hz but the more important part when setting the crossover on the alpine decks is to turn up the db slope on the crossover. It comes factory set at 6db or 0 on the screen. If you hit the power button 3 times you can bump it up to a 24 db slope which i think sounds the best in my car.
so on the screen it will be 0 4 80
GolNat
Nov 27, 2018 03:32 PM
JMKendrick
Sep 16, 2015 06:17 PM
Wheela
Wheels and Tires
Sep 7, 2015 02:14 AM
JohnDay
Wheels and Tires
Sep 6, 2015 06:42 PM
