AM Reception
Old Aug 9, 2003
nohone's Avatar
nohone is an unknown quantity at this point
AM Reception
My HU (pio. deh-p7500mp) isn't getting AM reception.
Would anyone happen to know what's wrong?
Old Aug 9, 2003
WhiteRabbit's Avatar
insufficient ground. ive tacked on stuff like FM modulators or LOC's to the stock ground on the wire harness and lost AM reception.
try finding a more solid ground
Old Aug 10, 2003
LudlamTheory's Avatar
i boogie for the raindrops
AM still exists?
Old Aug 11, 2003
tom1178's Avatar
tom1178 is an unknown quantity at this point
Only time i have personally used the AM stations was to try and find sports stations that are broadcasting nfl games, which will be coming very very soon. God i can't wait for something else to be broadcast on sportscenter besides boring old baseball. ok this is off-topic so i will stop now.
Old Aug 11, 2003
nohone's Avatar
Thanks. Definitely will try that when I get the chance. My dad's complaining about it that's why.
Old Aug 11, 2003
tbone323's Avatar
tbone323 is an unknown quantity at this point
what kind of amps do you have? If you're rrunning class D, they will most likely kill your AM reception.
~Tbone
Old Aug 11, 2003
AlpineCivic's Avatar
Your problem is your power antenna!!! Some people dont even know that are cars have powered antenna's. If the power antenna is not powered on you only get FM and no AM trust me it's happened to me!!\
You need to power the Yellow/Green wire in the factory harness in order to get full Radio reception.
Old Aug 11, 2003
a class D amplifier kills your am reception? that seems kind of silly....
how does class D affect AM reception?
Old Aug 11, 2003
KeNsHiN's Avatar
LEVA
Originally posted by LudlamTheory
AM still exists?
lol i though they really ment XM lol
Old Aug 11, 2003
tbone323's Avatar
ok, i'm not a RF expert but I will try and explain this the best I can...
Class D amplfiers switch the output from -HV to +HV (as you prolly already know) The output is a PWM waveform at some carrier frequency. Those severe transients produced from the squarewaves creates harmonics of the carrier frequency. These high freqs are radiated out of the amp (now here is the part i'm not positive HOW/WHY) either its radiated thru the air, or maybe the wires connected to the amp which disturbs the AM reception. If the amplifier has a lot of Ferrite beads to reduce this noise, then it may not be an issue. But I do know that RF's BD's will essentially eliminate your AM. I don't know if this is tru for all cases but I know its a prevelant problem that isn't really addressed because like LudlamTheory says "AM still exists?"
As mentioned above, this is not my area of expertise so if you disagree with something written above, i will gladly listen but this is true to the extent of my knowledge. If this answer isn't suffecient for anybody, I can talk to my boss (The VP of Eng here at RFafter 5 hours of him lectureing to me, I can try and decode what he tells me to offer a better explanation.
~Tbone
Old Aug 12, 2003
nohone's Avatar
hmm... now i'm gonna have to decide whether to ground or power the antennae. i'll try both i guess.
AM does exist. No, I particularly would never use it. But beng that my dad's Korean... 1480AM happens to be a Korean channel. Then there's your typical news channels that my generation of parents love. haha.
I'm not running any amps as of yet, so that's not the problem - but will keep in mind when I do drop them in.
Thanks for the help guys.
Old Aug 12, 2003
BabaBooey's Avatar
BabaBooey is an unknown quantity at this point
You must hook up the power antenna wire! The wiring adapter won't have that wire so you have to make a jumper from the Honda wire to the Pioneer power antenna wire.
Old Aug 12, 2003
nohone's Avatar
Problem's been solved. It was the power antenna wire as was mentioned.
Thanks everyone
Old Aug 14, 2003
BlackIce's Avatar
BlackIce is an unknown quantity at this point
~Tbone
how do you know all this with that tiny little brain of yours. lol
Old Aug 14, 2003
no, i dont disagree, i jus ttotally didnt know, sounded like an odd pair of things to be related
i just have one thing i was hoping you could clarify. and that is where does the ferrite bead go, and what is its structure? is it jsut that, a bead made out of ferrite? if so, where do they put them to control the carrier wave harmonics?
Old Aug 14, 2003
oo, oo! lemme guess first, i had a thought that i pulled out of my rear end.
do they go around the ouside of the output wires that transmit the carrier frequency and act essentially as a faradyay cage for the harmonics, not allowing any to leave the amplifier?
Old Aug 14, 2003
so ferrite beads are good?
Old Aug 14, 2003
tbone323's Avatar
ferrite beads are used to supress EMI signals. They are found on the inputs and outputs of electrical equipment so as to not malfunction due to input EMI or transmit EMI down the line.
You prolly have seen them before...they can be used outside of the device on the cables or, more commenly, the ferrite beads are internal.
The prob is they are not cheap and as you ALL know, to companies, its all about the bottom line and if its not cheap, it prolly won;'t be included (unfortunately).
~Tbone
Old Aug 14, 2003
can one add ferrite beads to amps?
and if one did, what improvement would one see?
and if one could add one, how would one add one?
Old Aug 14, 2003
tbone323's Avatar
its not a very interesting topic...
http://www.act1.com/emi_tut.html
this topic is boring me (you prolly won't notice ANY diff) because it blocks RF and EMI signals so you may* get better radio reception, but your audio coming out of your amp wont sound ANY better.
~Tbone
Old Aug 14, 2003
Hefe's Avatar
Second Place is the First Loser
Hefe is a jewel in the roughHefe is a jewel in the roughHefe is a jewel in the rough
Thanks everyone
So how did you solve it?? ground or Power?
Old Aug 15, 2003
nohone's Avatar
it was the power antennae... yellow/green wire. I ran it into the amp remote wire so it turns on with HU each time.
i didn't even bother with the ground.
Old Aug 15, 2003
Hefe's Avatar
is that wise to do??? wire it to your remote wire?
Old Aug 16, 2003
yeah, if you dont have a power antenna wire
Old Aug 16, 2003
Hefe's Avatar
damn.... I guess ill do that (i have a Pioneer radio too)... I listen to A LOT of AM.. and the signal is SHITTY!!!!!!!!
Can't wait
Old Aug 17, 2003
Hefe's Avatar
damn it... it didn't work... I tapped into the Yellow/Green wire from the factory harness... and plugged it into the remote turn on wire from my radio... and i still get a shitty static am.... I used one of those crimp on wire thingies... (the one where you put the wire you are tapping from in the long hole, and the recieving wire right next to it and close the little metal thingy and click it shut.. )
Old Oct 22, 2003
tom1178's Avatar
Sorry for digging this post up after 2.5 months, but i just had to solve this problem because i left work last night and was listening to the MNF game at work and i couldn't listen to it in my car because for am all i hear is crap, i get one AM station in my car but none of the ones that play sports. thanks for all that posted with good info, i just need to rip out my HU...again...got i hate doing this, it's such a pain in the **** to me since i got my civic, it was sooooo easy 2 yrs ago when i drove a......well i drove a dodge neon but atleast in the neon i could steal/remove a radio in under 15 seconds. i guess thinking about it now i'm glad our civics are harder to get at the HU.
this is just postive proof that the SEARCH FEATURE works, so get searching you noobs, i posted quite a bit on this site last spring but stopped because all the "new" posts just seemed to be about the same old questions that were talked about previously.
ok we can let this thread die now, please nobody reply unless it's good, unlike my post here.
Old May 25, 2004
syndrome's Avatar
syndrome is an unknown quantity at this point
Somebody solve this problem!
Old May 25, 2004
PopcornPlaya's Avatar
Electric Boogaloo...
Problem with AM reception, along with FM reception in our cars? The antenna is in the back window. If you tinted over it, it's worse than it was before.
Old Jun 1, 2004
hondah1's Avatar
hondah1 is an unknown quantity at this point
I have the same problem with my Alpine 9807. I tried connecting the yellow/green and blue wires with no luck. Can someone explain exactly how to connect the power antenna lead? I called a couple of local places for some info and all I got was a "your car doesn't have a power antenna". I can post a picture of my setup if needed. Thanks.
