Front speaker replacement - 2002 Civic EX Sedan Automatic Vtec?
Old 10-28-2016
MamaBear2015's Avatar
MamaBear2015 is an unknown quantity at this point
The previous owner of this car blew out the driver's side front speaker ( moron ). If I go to Crutchfield, they have tons of reasonably priced speakers for this. But how easy is it, to do myself? Do the covers just snap off, you unscrew the speakers and replace them? 1/4" lug connectors, perhaps? ( OR I can solder well, being a former Electronics Research & Development Technician with an ASET ( Associate in Science in Electronics Technology ).
Don't see videos on Google for this.
Old 10-29-2016
Re: Front speaker replacement - 2002 Civic EX Sedan Automatic Vtec?
Remove the entire door panel to access speaker.
Old 10-29-2016
Eeek.
Old 10-29-2016
thetut's Avatar
thetut is a glorious beacon of lightthetut is a glorious beacon of lightthetut is a glorious beacon of lightthetut is a glorious beacon of lightthetut is a glorious beacon of lightthetut is a glorious beacon of light
Not as hard as you would think.
See here:
Old 10-29-2016
See here: ...
Thanks! It happens that I need to change both the door handles anyway - the chrome is bad and has been causing the equivalent of paper cuts at times. I have them, but have been procrastinating.
Old 10-31-2016
GusBuz's Avatar
GusBuz is a jewel in the roughGusBuz is a jewel in the roughGusBuz is a jewel in the rough
The front speakers are held in by clips. You have the option of drilling holes into the metal and mounting the speakers that way or using the old speaker as a mount for the new one. This last option also helps as a spacer because the mounting depth is 2" if its more than this your speaker wont fit, I believe the window regulator bumps into it if its not a shallow speaker.
Anyway i found two videos showing this last method of install.
Old 10-31-2016
This is beginning to sound like I'd better have a sound place do this. I thought it might be simple.
Old 10-31-2016
GusBuz's Avatar
Tell me about it Ive had new speakers waiting to be installed for like 4 months lol
