2012 Eibach front Sway Bar too big?
Old 08-30-2015
Shadow277's Avatar
Shadow277 is an unknown quantity at this point
Hey guys, quick question. I bought the Eibach sway bars for the front and wear of my 2012 Cvic Si.
I hear a scraping noise similar to sound. Turning I hear absolutely nothing. When I decelerate the car
pulls to the left. Did I screw something up? I followed the guide exactly and I had my buddy who is
an Army mechanic help me.
Any assistance on the matter is a appreciated!!
Front sway bar: 24mm
Old 08-30-2015
Re: 2012 Eibach front Sway Bar too big?
When I decelerate the car pulls to the left. Did I screw something up?
Something very important was left loose?
Lower control arm mount?
Subframe?
IDK, revisit with wrenches everything that you touched.
Old 08-30-2015
Shadow277's Avatar
Subframe?
I had done just that. The only thing I noticed was the drive shaft scrapping against the sway bar. Paint chipped, nothing else. I tooke it to Fire Stone and they said some sort of steering bolt broke off. Probably from these shitty Military base roads.
Old 08-30-2015
Wrong length end links?
Did they fix it? Did that solve the pulling problem?
I kinda doubt it was the fault of the roads unless it was a fluke failure.
Was it a bolt anyone had previously touched/loosened/removed?
Old 08-31-2015
Shadow277's Avatar
According to them the control arm hit the strut and damaged it. A bolt broke off that held the control arm. They replaced a bolt where the sub frame is. It drives fine now.
mrohitredd
06-09-2015 06:37 AM
Rogelio Rey
05-24-2015 08:30 PM
Dorval Andre
05-01-2015 09:37 AM
bsmiley
04-27-2015 01:27 PM
JeffSpeed21
11-03-2001 10:32 AM
Quick Reply: 2012 Eibach front Sway Bar too big?
