Key chip removal
Old 06-26-2015
GunnersDaddy's Avatar
GunnersDaddy is an unknown quantity at this point
Key chip removal
Can anyone help me with a question on removing the chip in the remote. I want to know if I remove the chip from the remote to relocate it in a flip key I bought, will it lose the programing. Does it need wire leads to it? Just don't want to do it when I have only one working key and need to tow it to Honda
Old 06-26-2015
RIPSAW's Avatar
RIPSAW has a spectacular aura aboutRIPSAW has a spectacular aura about
Re: Key chip removal
The immobilizer on the valet key does not have a battery. However, you program car to it. Guess if you are careful, you could get it out of plastic. My 07 only had one key. Dealer charged me $90 for a valet key and program. Had to have car to do it. Beats having it towed if you happen to lose key
Old 06-26-2015
All i have is one master key that the metal cut portion broke off. I have been able to still use it but would like to have the flip key work instead.
Old 06-26-2015
What car do you have?
Here's the two places it could be
Check your key:
No wires, no batteries. Car remembers the chip, not the other way around.
If its stuck inside the head of the key, carefully cut it out and move it to the new housing.
Make sure it's placed close enough to the key to be read by the antenna ring in the steering column.
If not stuck in the shell of the key
Check inside your remote fob:
If the chip is soldered to the remote fob board, IDK. I haven't researched it myself. Found this thread while looking though
HTH?
Old 06-27-2015
I have a 2007 civic Lx with the two button remote. My chip is saudered onto the circuit board. Just didn't know if I could take it off with out loosing the programing.
Old 06-27-2015
RIPSAW's Avatar
Sure hope you are good at soldering and have one of those small solder vacuums tools. Got mine from Ebay for a few dollars. The programming does not depend on the battery but who knows. Let us know. That's a good one. Guess the next car I get will be a HRV with a push button. They say it comes with a coupon to get the eprom surgically implanted.
Old 06-27-2015
emich's Avatar
emich is an unknown quantity at this point
You can cut the plastic both sides of the key. the chip is there. no wires.
you can request from Honda dealer providing your VIN temporary code to drive the car there with any key when you need programing.
Old 06-27-2015
emich's Avatar
You can cut the plastic both sides of the key. the chip is there. no wires. (7 gen. civic)
Old 06-27-2015
Thanks bro.
Old 06-27-2015
Do you know a dealer i can call for the temporary code. The dealer here says there is no such thing. Removed the chip and now the new key with the chip in it, won't start the car. Damn. To the dealer for a new set of keys
Old 06-27-2015
The code you need is called "Immobilizer brake code".
Use of this may allow you to drive the car to the dealer to get it programmed, saving you a tow truck fee.
They will need your VIN to get the brake code.
They will need to explain how to use the code or maybe walk you through it over the phone.
Old 06-27-2015
RIPSAW's Avatar
Here is the procedure for what ezone just said. http://automotiveandcommerciallocksm...edure-for.html
this guy says he could have fixed it. http://fixmykey.com/
Did you pull out the immobilizer chip or the soldiered alarm chip.
Old 06-29-2015
emich's Avatar
the chip should be in the same place in the new key or it will not work.
Take a look at this
Old 07-09-2015
"Honda - tried, true & tested...!"
brags's Avatar
brags is an unknown quantity at this point
Cool Nice pic Ezone of the key..!
danace99
23
06-28-2015 08:49 AM
nufc
Legal Questions and the Law
06-21-2015 09:57 PM
bluedoggy1
06-20-2015 11:25 PM
CaseysGuy385
01-21-2002 08:44 AM
Quick Reply: Key chip removal
