12v Ingition OnPower Under the Hood-Where to Find?
Old 08-06-2011
All Ahead Flank's Avatar
All Ahead Flank is an unknown quantity at this point
2006 Civic
I'm having a devil of a time trying to find a 12v source in the engine compartment that is only powered when the ignition is ON. I don't what to have to run a wire from under the dash into the engine compartment. Can anyone help?
Thanks
Old 08-06-2011
lazlong's Avatar
Re: 12v Ingition OnPower Under the Hood-Where to Find?
Go to the fuse box and 1 by 1 pull the fuses and test for power in the fuse socket when ignition is on. Get a friend to turn the ignition on and off or it'll take forever. Once you find the one you want use an ATC add-a-circuit:
Old 08-06-2011
Thanks very much. This helped a lot!
I found only one fuse in the engine compartment fuse box that did not have power to it all the time. It is a 7.5A IGPS Oil Level fuse. I did notice that whenever I turned the key off, it took about 30 seconds for the voltage to go away after hearing a relay click. I guess I can live with that.
Default_Slayer
Electrical DIY
12-04-2022 07:56 AM
trellex
06-30-2015 07:13 PM
sbi
06-12-2015 11:59 AM
NukeSilo
11-20-2001 05:17 PM
TropiKalCiviC
09-25-2001 07:02 PM
Quick Reply: 12v Ingition OnPower Under the Hood-Where to Find?
