After inspection brake lights are intermittent
Old 02-19-2010
kdiamore's Avatar
kdiamore is an unknown quantity at this point
Angry After inspection brake lights are intermittent
I just got my car inspected and before going I checked all my brake lights, all were working fine. I go, look at the report..passed, but it notes my 3rd brake light not working. Weird since it is LED and was working fine that morning. I check it.. sure enough not working. Later that day, I can see its working again from inside the car. I stopped at Target, came back out, not working. Now I had someone check my lower rear brake lights and the left one is out. Is there something they could have done at inspection that could've caused this? I think I saw them under my fuse box do they by chance plug into the computer or something. Any help is appreciated!
Almost forgot, its an '06 Civic Coupe EX
Old 01-15-2011
Wzahpnn's Avatar
Wzahpnn is an unknown quantity at this point
Re: After inspection brake lights are intermittent
I have a similar problem...the 3rd brake light seems to work when the main car lights are turned on, but doesn't work with the lights are turned off. The right and left brake lights work just fine either way. Can't figure it out?
Old 01-15-2011
Live for the Twisties
MindBomber's Avatar
Most likely there is a bad ground connection causing the problem.
Old 01-15-2011
there are sooo many problems with those EX LED brake lights. not the unit itself, but either the connector plug or the wiring. i would start at the connector right near the lamp and unplug it. grab a multimeter and test light and probe the connector coming from the car side with someone stepping on the brakes. if it gives a 12v reading or lights up a bulb every time, then its the connector. in which case, you need to cut and splice the wires (and solder them) by cutting the connector off. if you sometimes do not get power at the plug, then you need to trace back the wiring and see if there is a loose connection.
Dorval Andre
General 7th Gen
28
07-21-2022 05:53 PM
Poopies
04-20-2017 11:36 PM
Ma213802
05-18-2015 07:01 AM
ywgflyer
05-15-2015 05:05 PM
OoSiLvErCiViCoO
11-14-2001 11:35 AM
Quick Reply: After inspection brake lights are intermittent
