Installing amp/sub with stock stereo.
Rep Power: 0 Installing amp/sub with stock stereo.
Basically I just need to know if the stock stereo has the rca outs and remote wire somewhere so I can hook up my amp and sub. Kind of sucks there is no way to replace the head unit with something else without doing a major cut and patch job to the dash.
If it isint possible with a third party sub/amp how would the factory one get hooked up?
Rep Power: 0 Re: Installing amp/sub with stock stereo.
So theres no other way?
That one on ebay has the cut out too big. It's just a standard size deck so it would only fill half of that.
I would rather keep the stock look if I can. Not too unhappy with the sound, just needs more low end.
Whachya lookin at?
Rep Power: 290 Re: Installing amp/sub with stock stereo.
Sorry I realize that I'm not answering your questions. That kit has a setup for either single DIN or double DIN decks. So it's up to you on how you use it (read his description). I would upgrade from the factory any way, can't go wrong with upgrade. I did come upon this while doing a bit of searching though.
http://www.8thcivic.com/forums/audio...actory-hu.html
Good luck!
Good luck!
Thanks for the help and links. But looks like it will be staying stock for now. Way too much splicing into factory wires for my liking.
Received 1,161 Likes
Rep Power: 486 Re: Installing amp/sub with stock stereo.
This is basically how me and my dad wired up my system on my last 2 cars to the OEM head unit.. Up until I spent the money and got a full sound system.
cut the wires going to the rear speakers, wire them to RCA terminals, use those as an input to a crossover (to let it filter out high freq and low freq sounds), and then have the R/L outputs go back to the speakers, and the sub output go to its amplifier. You can even go as far as amplifying the rear speakers, but I don't know how much power they can take.
As for the remote wire, we just used the radio's accessory wire to send the remote signal, so that the amp turned on every time the car was put into at least acc. mode
Whachya lookin at?
aye, get an aftermarket head unit... its so much easier and the sound even though you are happy, is better. I'm pretty sure you don't have to splice any wires for an aftermarket one... if you decide you wanna go back to stock you can always put the original back in.
Get a cheap Alpine for 130 bucks and you will be more than happy.
Thanks riceboy, that does simplify things somewhat. I wonder if there is a way without the cross over tho. My amp has one built in but only has a pair of rca ins. If I made the rear speaker to rca splice so I have one pair to go to the amp should that work. As opposed to your rca in and out with x-over then to the amp.
@tbohar. I do have a nice HU sitting in my dead golf, but I guess I should have mentioned the car is a lease and I really dont feel like taking apart the dash and dealing with mounting brackets and wiring harnesses and also getting a new chunk of dash, and then doing it all in reverse in 4 years.
Guess well see how ambitious I feel one of these weekends.
What kinda car you have? My 2018 still has a cigarette lighter adapter.
It's a 2013. I found the fuse I was looking for. I call it a cigarette lighter but I guess it's the 12v plug for ur cell phone charger or whatever else. I used the #2 10amp fuse. Worked like a charm. I dont remember right off what it was labeled. Thanks for the help
StickShiftDrifter
21
10-02-2006 06:04 PM
