Wheels, Tires & Brakes Modifications Post Wheel, Tire & Brake related modification information and/or questions here.
Brake Pad suggestions for 09 CRV?
Old 04-17-2012
whatacar's Avatar
whatacar is an unknown quantity at this point
Heading in for a B1 service on our CRV, 4wd middle modle. Has 74000 Km, bout 45 000 mi. The service guy said that part of the recommended service is to take apart the breaks and lube em to make sure all parts move freely. Hmmmmmm, so I'm thinking they'll probably say I need break pads as well. I'd like to pick up a set (F&R) and when they give me the news, tell them the pads are in the back seat. Any suggestions or shall I just go OEM? I'm in Canada btw.
Thanks in advance.
Old 04-18-2012
CraigW's Avatar
Re: Brake Pad suggestions for 09 CRV?
If you a conservative driver... you should not need pads that early.
They will inspect the pads and I assume clean the slides.
I'm planning on going about 3.5 years on my 2010 Civic and do brake fluid change and pads at the same time. I should be at about 65-70k miles.
Old 04-19-2012
whatacar's Avatar
Well I was surprised, they noted what was left on the pads (4.5 mm F and 6.5 mm R) and made no attempt to upsell. They said they recommend replacement at 2 mm. Went out and bought a lottery ticket as it was obviously my lucky day.
Thanks for your thoughts CraigW.
Star1967
06-08-2015 04:23 AM
rhvic
05-22-2015 03:06 PM
ayoitzjulesdx98
05-14-2015 08:29 AM
bsmiley
04-27-2015 01:27 PM
BlueIce2001
01-20-2002 03:09 PM
Quick Reply: Brake Pad suggestions for 09 CRV?
