2008 vibration 900rpm to 2200rpm
Old 10-22-2013
poolboy72's Avatar
poolboy72 is an unknown quantity at this point
Well I have read a lot on this issue, many posts saying motor mounts and such. Being a machinist myself (not an expert Honda mechanic),I have checked these mounts myself and carried to a local shop for them to look at it and see what they thought this vibration is. We both agree they do not seem to be bad =, no visible cracks or a lot of play while shifting from park to drive gears. I put a little pressure on the engine to seem how much movement was in the mounts and it does move a little but doesn't seem to be more than normal. I also don't think its contacting metal either. Just above idle it starts and just as it breaks 2000 rpms it goes away. the mechanic at the shop thought it might be the catalytic converter, but this doesn't seem logical as to the higher rpm it should get worse? More air greater back pressure ? and we also put the code reader on it and it doesn't show any codes ............. Any help would be greatly appreciated!!!!!
2008 civic 2dr 1.8
Old 10-22-2013
Re: 2008 vibration 900rpm to 2200rpm
Vibration goes away in reverse?
Sounds like a fart can muffler on it?
Engine mount, passengers side.
This is the only mount I have had to replace since these cars came out.
You might find where it has separated once you get it all apart.
Copied from another post in this site
Collapsed mount
New mount
Someone leaving the oil cap off the engine makes an unusual noise too.
mgrantaz
General
05-02-2022 05:40 PM
jdawgzcivic
17
02-01-2020 04:16 PM
Wariogamer
09-29-2015 09:49 AM
vImpostor
Vancouver
09-08-2015 08:08 PM
FistRock
09-04-2015 08:00 PM
Quick Reply: 2008 vibration 900rpm to 2200rpm
