2008 Civic Check Engine Light
Old 05-06-2013
JasonBanz's Avatar
JasonBanz is an unknown quantity at this point
Good afternoon! I have a 2008 Civic EX 5 spd. I have a constant check engine light now. A few days before coming on it says check fuel cap. I purchased a new fuel cap thinking it would fix it. It did not. Light was reset and then it came back again. Still reading the original small vapor leak detected. Anyone with a similar Civic had this problem?
Old 05-06-2013
Former Sponsor
go-part's Avatar
go-part is an unknown quantity at this point
Re: 2008 Civic Check Engine Light
http://www.aa1car.com/library/evap_system.htm
Old 05-07-2013
JasonBanz's Avatar
Yay! Joy! I have the small vapor leak reading. I've seen this is common with 2008 Civics. Thanks for the reply. Anyone else had this problem?
Old 05-07-2013
Code P0456?
Find Honda service bulletin 08-013. (I did not find it on a quick Google search.)
Maybe try ALLDATAdiy.com, or your local library. Many libraries have access to Alldata and/or Mitchell service information.
The bulletin tells about the EVAP purge valve as a possible cause.
Gives VIN ranges of affected vehicles
Tells how to inspect it and properly diagnose it.
Tells how to replace it if it is actually found to be bad.
Xuhme
21
08-07-2023 03:40 PM
ashleymmackey
04-18-2015 09:48 PM
CascadiaBlue
04-18-2015 09:13 AM
bahena08
04-11-2015 05:09 PM
Quick Reply: 2008 Civic Check Engine Light
