07 Rear Suspension
Old 08-28-2012
ab_329's Avatar
ab_329 is an unknown quantity at this point
07 Rear Suspension
Hey guys, so I have been reading about all the issues with the 06 and 07 civics rear suspension. I have the same issue with mine and I have gone through several sets of tires and have looking for a solution. I installed a set of camber washers on the rear and have taking it for alignment. Now as I see the results from the print out, the specs show to be with in range. The range is -2.5 to -0.5 or something like that. I assume these are the specs for this model year and are considered correct. To me that is incorrect as it is not at zero. How can I get an updated alignment spec sheet or how can I resolve the issue if the alignment shop is using the specs for that model year car? Another thing I noticed is that the camber kit doesn't give me a whole lot of adjustment. I have seen pics on here that some kits have a different set of holes to bolt on too. Mine didn't have that. Any help is appreciated.
Thanks
Old 09-09-2012
RED ROCKET
badolboy's Avatar
badolboy is an unknown quantity at this point
Re: 07 Rear Suspension
i have an 06 ex coupe looking at a full eibach kit,
with adj. front/rear camber kits, but unsure of struts
let me know , how you make out. , jc
juror
Suspension DIY
07-30-2019 03:28 AM
EdGasket
40
11-27-2015 11:11 AM
Curtchuk
08-05-2015 02:14 PM
Strycker
08-02-2015 08:40 PM
Misfit2613
07-30-2015 09:49 AM
Quick Reply: 07 Rear Suspension
