2011 Honda Civic
Rep Power: 0 2011 Honda Civic
The car only has about 1000 miles on it, but when you try to start the car, the key is turned all the way over, all lights are on but the car will just make a humming noise but not start. Usually you have to key putting key in and out and turning it over and then will finally start. It only does it periodically, so dealership will not fix and has left me stranded
Re: 2011 Honda Civic
Sounds to me like your ignition isn't registering with the computer chip in you key. Try using the 2nd key the dealership gave you or see if your warranty will cover them reprogramming your keys to your ignition
I have a 2011 civic lx coupe & am experiencing the SAME exact problem. I have had it to the dealer 4 times & have recently bought a flip cam to video the problem. I already have a lemon lawyer waiting so I can either get a new one or my $ back!
A true genius admits that he/she knows nothing.....CLOSED SAT/SUN
Rep Power: 164 Re: 2011 Honda Civic
I agree it kinda sounds like the chip in the key is not working..try the other key and see if it works.. make a video of it.. Go to the dealer..they can't leave you stranded its under warranty..go to a different dealer if you have to.
I have a 2011 Civic with 20,000 miles. I took it in a 15,000 because of the identical starting issue - happens on an intermitent basis. The dealer could not duplicate the problem. I have it at the dealer again today at 20,000 miles - dealer cannot duplicate the problem. I asked them to keep the car antoher day and keep trying. I know when I bring it home I will turn the key & it will not start...very frustrating. I am at the poiint where I do not want this car - thinking it will just die when I hit 30,000 & warranty expires.
Rep Power: 787 Re: 2011 Honda Civic
if you are really good with electronics and have the electrical service manual, you could wire in a bypass harness for the immobilizer and delete it completely. its one of the most useless things honda came up with, after the radio security code. it would require lots of rewiring, and if done properly, the car will start up normally with any matched key (no programming). but the downside is the green key light will always be on, which you can put a tape behind to cover it, but also the check engine light will stay on, so you will not know if there are other problems unless you keep scanning for codes every so often. i wanted to do this a while back but its tied into all the critical systems and i didnt feel like wasting the time hacking up wires.
The Problem On The 2011 Honda Civic The Dealer Think Is The Starter But It Is The Safety Parking Swicth I Have That Problem To The Dealer Replace The starter And The Problem Continue And A Mechanic Say Is That Swicth So I Will take It To The dealer Tomorrow.
It just sounds like u have a starter engine problem, can be many things in that little thing, parts are rare to find so fixing it will be pretty expensive, but buying a new one would be recommended be many, even mechanics, it would range from 120 to even 300 depending were u go, all are the same so don't pay more and get the right one. I had the similar problem, but my dad being a mechanic he knew the problem from the second he saw it. I can say my car is working as knew again and I to have a 2011 civic, and no the starter does not fall in their warranty, I checked the book and online numerous times, so this fix is a must unfortunately.
Hope this helped
Hope this helped
jessicakaybby
04-20-2015 12:11 PM
