No power to dizzy ph
Rep Power: 0 No power to dizzy ph
D15b2 mpfi pm6 ecu . I don't have power to my white igniter wire on the dizzy plug at none of the turns of the key. hopefully that makes sense. I do have continuity from the white igniter wire on the dizzy plug to the ecu. I opened the ecu and measured from the inside the ecu to the dizzy plug. I have constant 12v power to pin 17 on plug A. there is no wires to that pin. could I put wires to pins 15 & 17 on plug B which go to the ecu from the igniter wire on the dizzy to pin 17 on plug A?
Dr Krieger of Modification
Re: No power to dizzy ph
But you have power to everything else right, gauges/ starter?
Check your grounds as well If there is a missing head ground then V+ will not flow even with continuity to ecu.
