95 civic transmission issues
Rep Power: 0 95 civic transmission issues
I have a 95 civic sedan.. the old transmission was toast so i put in a used one it was fine shifting smooth for about a couple miles then it wouldnt shift from first if i put it in d1 it goes to first d2 second but d3 and d4 are like netural... i used max life tranny fluid to.. i switched the solanoids from the old tranny and still wont shift any ideas
Re: 95 civic transmission issues
Sounds like you got a junk transmission.....or you didn't clean out the ATF cooler and leftover debris from the previous trans failure contaminated the new one.
Rep Power: 0 Re: 95 civic transmission issues
Ended up changing the fluid and adjusted the throttle cable and kickdown is there any way i should put the kick down do i want it tight or kinda holding the arm up ...it is shifting kinda weird to
Oooh, I didn't even think about that having a cable....durrr LOL
it's been a long time since I saw a car that old
Gotta synchronize movement of trans lever exactly with the throttle
try this
try this
