Go Back   Honda Civic Forum > Honda Civics by Generation > 1st - 5th Gen
Register Forgot Password?
Register Photo Gallery FAQ Members List Search Today's Posts Mark Forums Read Experience GarageVendors TSB & Recalls
Welcome to Honda Civic Forum
1st - 5th Gen In the years from 1973 to 1995 Honda released it's 1-5th Generation Civics
LinkBack Thread Tools Search this Thread
Old 10-04-2010   #1 (permalink)
psychexero is an unknown quantity at this point
95 Honda Civic Starting issues
I have a 95 Honda Civic EX, manual transmission. The problem that I have with it starting is that after I put the key in, push in the clutch and turn the key, I get a soft click, and no start. Sometimes after waiting a while or pumping the clutch (I'm pretty sure that's coincidence when it works) it will eventually start. However, that momentary panic of the car not starting is getting old. It doesn't happen all the time, it seems to be very intermittent. Some mornings it behaves! Once the car is started in the morning, it starts fine for the rest of the day.
So far I have replaced:
Spark plugs
Fuel Pump
Distributor
ICM
Wires are good, they were recently replaced and tested when spark plugs were replaced.
Battery was replaced last summer, good current there.
Any suggestions? A direction to go? I'm at my wits end (and so is my dad!)
Thanks!
psychexero is offline   Reply With Quote
Old 10-05-2010   #2 (permalink)
J-Master Flex's Avatar
Points: 2,090, Level: 27
Points: 2,090, Level: 27 Points: 2,090, Level: 27 Points: 2,090, Level: 27
Level up: 60%, 60 Points needed
Level up: 60% Level up: 60% Level up: 60%
Activity: 6.5%
Activity: 6.5% Activity: 6.5% Activity: 6.5%
J-Master Flex is an unknown quantity at this point
Re: 95 Honda Civic Starting issues
If you haven't already done so, check the timing to make sure you're engine is firing properly. If it's not that, it could be your alternator. If both of those are fine, then when you try to start your engine, turn the key to "On" but don't start it until the fuel pump is done pressurizing the system, see if that works better for you.
Is your engine cranking but not turning over, or is it clicking noise made when the battery is dead?
J-Master Flex is offline   Reply With Quote
Old 10-05-2010   #3 (permalink)
This morning I started thinking it was the alternator. It's like it just doesn't quite have enough power to turn over.
I doesn't crank, it just gives one click (not the click click click I'm familiar with on alternators going out). Everything else will power on...
When I tried starting it, after coaxing it from clicking, it gave a half-hearted attempt at starting... I gave it about a minute and tried again, and it fired right up. But I shut it off, came inside, started coffee, went back out (5 minutes max) and we're right back at square one. It's like the alternator isn't charging the battery, or SOMETHING.
And I've already been waiting for the fuel pump to pressurize, but thanks for the tip there!
Old 10-05-2010   #4 (permalink)
Trance Addict
MelJ's Avatar
Points: 6,002, Level: 50
Points: 6,002, Level: 50 Points: 6,002, Level: 50 Points: 6,002, Level: 50
Level up: 26%, 148 Points needed
Level up: 26% Level up: 26% Level up: 26%
Activity: 1.7%
Activity: 1.7% Activity: 1.7% Activity: 1.7%
MelJ is a glorious beacon of light MelJ is a glorious beacon of light MelJ is a glorious beacon of light MelJ is a glorious beacon of light MelJ is a glorious beacon of light
MelJ87
Send a message via AIM to MelJ
Mine did that a few times. Turns out I had loose connection on the battery terminal. I had to ghetto rig it because the cable is kinda messed up ATM. I mean, that might not be the issue at all, but better to start with the common sense stuff first.
__________________
2000 Civic Si- Short ram intake. Yeah. Rollin' in the mods, kid.
Brakes-These slow the car down!
Break-This is what twigs and sticks do!
Quote:
Originally Posted by lazlong
*Before any of ya say "WTF does VTEC have to do with a hard start?" I'll tell ya I got it straight from the manual and have no idea.
6th Gen Manual
Please PM me for broken links
MelJ is offline   Reply With Quote
Old 10-05-2010   #5 (permalink)
Activity: 6.5%
I had my alternator sieze up completely just recently, and the car was very weak when turning over, and my Check Engine Light came on as a result. Replacing an alternator is pretty easy, as long as the bolts aren't siezed up. Run you about $200 for the part if you trade in your core, and I'm sure a shop will charge you twice as much to do it.
Old 10-05-2010   #6 (permalink)
Yeah, my intent is to take my car to an autozone or o'reillys tomorrow to have them test the alternator/battery. And go from there. Other than those options (I checked the terminals, they're still clean and well connected!), any other directions to go/look at?
Old 10-05-2010   #7 (permalink)
lazlong's Avatar
Points: 16,612, Level: 82
Points: 16,612, Level: 82 Points: 16,612, Level: 82 Points: 16,612, Level: 82
Level up: 53%, 238 Points needed
Level up: 53% Level up: 53% Level up: 53%
Activity: 4.9%
Activity: 4.9% Activity: 4.9% Activity: 4.9%
lazlong has much to be proud of lazlong has much to be proud of lazlong has much to be proud of lazlong has much to be proud of lazlong has much to be proud of lazlong has much to be proud of lazlong has much to be proud of lazlong has much to be proud of lazlong has much to be proud of lazlong has much to be proud of lazlong has much to be proud of
Quote:
Should be a guy in your town who rebuilds alternators and such. Find that guy and they can usually get it rebuilt for $50 or so and you can usually have it back the next day.
lazlong is offline   Reply With Quote
Old 10-06-2010   #8 (permalink)
Activity: 6.5%
Quote:
Unfortunately, I live in a town where it's hard to trust the mechanics unless you personally know them. And the one's I personally knew don't rebuild alternators. Besides, I figured I wouldn't have to worry about one that was fresh from the factory. Even with the added cost, I still think it was worth it.
Old 10-06-2010
CivicForums
Honda Civic
Paid Advertisement
Tags
1995 , 1997 , 95 , alternator , battery , civic , diagram , dx , engine , honda , images , photos , problem , start , starting
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
User Login
Our Partners
used new
Top 10 Threads
Need Underhood Fuse Box Diagram
Stuck Brake Light Switch
1995 Civic DX rough idle what causes it and how to fix
VIN Numbers: You should know where your civic was quality built!
D15B7 Timing marks question and confusion?
smells like gas inside my car
specs/info for the 1983 Civic 1500 S
My 95 Honda Civic EX Coupe
Engine ground wires
best gas milage setup
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
Content Relevant URLs by vBSEO 3.5.2
Emails Backup
