transmission noise
Old 05-25-2012
98civic47's Avatar
98civic47 is an unknown quantity at this point
transmission noise
hi im new to this and i have a issue with my 98 honda civic... its a jdm d15 and a 5 speed tranny... the problem is there is a weird noise coming from my tranny.... it doesnt make the noise all the time.. sometimes in first always in third and sometimes in 4th... it makes a rubbing like noise.. not sure if its my tranny or my clutch... the noise goes away when i push the clutch in as well. if you know what is the issue please let me know
98civic47 is offline
Old 05-25-2012
Member - 96 Civic Ex
Sobefreedom's Avatar
Sobefreedom is an unknown quantity at this point
Re: transmission niose
I am taking my 96 civic in next week to have the whole tranny rebuilt because the syncronizer is malfunctioning and i will get similar sounds and it even progressed to grinding when shifting into first gear unless the car is stopped. i hate trannies! relatively cheap parts, but the rebuild labor never is. my advice... if you have to rebuild the tranny. fix everything at once.
Sobefreedom is offline
Old 05-25-2012
98civic47's Avatar
so pretty sure its not the clutch then... why not buy another tranny then... it would be alot cheaper lol and if you know how you can put it inyourself
Old 05-29-2012
Re: transmission noise
True i could put a whole new tranny in, but i don't have the means nor the time to do so really. Plus with something that critical to the cars function, i want someone else to do it so it is covered under their warranty and they will fix it should anything happen between now and a year from now. anyways, good luck. FYI the guy i go to quoted me 560 for the labor alone and then parts are additional. just to give you a rough estimate.
Hqly2001
22
07-12-2015 06:44 PM
07-12-2015 11:54 AM
1khilari
07-09-2015 08:12 PM
fatih717171
07-08-2015 12:14 AM
fvckbg
07-07-2015 07:08 PM
Quick Reply: transmission noise
