Timing Belt + Water Pump
Old 03-07-2016
cukaracha's Avatar
cukaracha will become famous soon enough
Hi,
I'm going to be attempting my first timing belt + water pump replacement soon (with the help of an experience mechanic friend) on my '00 Si. What are the parts and components that I need to complete the job? I looked on HondaPartsUnlimited, but there doesn't seem to be a timing belt kit. I want to be sure that I have all the pieces I need to get the job done right the first time.
cukaracha is offline
Old 03-07-2016
Re: Timing Belt + Water Pump
Shopping list, off the top of my head:
Timing belt
all accessory belts (AC, alternator, and power steering, whatever your car is equipped with)
water pump
coolant
Maybes:
tensioner pulley for the timing belt (high mileage?)
front cam seal (oil leakage?)
front crank seal (may be called oil pump seal) (oil leakage?)
valve cover gasket set (and enough RTV or Hondabond to dab in the corners) (just because you have to lift it up to do the timing belt job...If it is relatively new it will probably be ok to reuse)
adjuster pulley for the AC belt, if it is noisy (check it as you disassemble parts)
Tools for the crank pulley?
ezone is offline
Old 03-10-2016
cukaracha's Avatar
Thanks for the reply!
I was thinking of purchasing a timing belt + water pump kit from Amazon (Gates brand) and then buying an OEM timing belt. Any thoughts on that? Should I be comfortable with just using all the components in the kit, or is buying an OEM timing belt a good idea?
Old 03-10-2016
The engine is an interference engine, meaning valves can contact the pistons.....so if anything in the timing area lets go, it's very likely you cost you a pile of valves and/or an engine. Plus a tow truck.
Do you want to cut corners?
I know I can trust Hondas parts.
ezone is offline
Old 03-13-2016
EdGasket's Avatar
EdGasket is an unknown quantity at this point
Why? You can just buy a water pump if you want; why buy two belts? A Gates belt will be OEM anyway; perfectly good to use. Just make sure its not old stock or one that has been opened. I bought a perfectly good Gates belt and tensioner kit from Amazon Prime but then for another car I bought a timing belt, packet had been opened and resealed and it looked as though it had been used. When I checked the belt codes with Gates it was well past its shelf life by several years. I think some lo-life had swapped their used belt into the packet and returned to Amazon for a refund.
Shelf life for a belt is 8 years I believe.
EdGasket is offline
Old 03-16-2016
Deksinjo's Avatar
Deksinjo is an unknown quantity at this point
Just buy timing belt, check is tensioner is make noice when rotate, if not don't replace. If you do regular coolant maintenance (change every 2 year) and if no leek under chek holl on water pump you don't need to change them.
Deksinjo is offline
fiveforwardgear
02-02-2016 01:36 PM
chi_tea
01-05-2016 10:49 AM
Vrikkian
Mid Atlantic
01-03-2016 11:12 AM
Johny Roque
12-27-2015 11:05 PM
Quick Reply: Timing Belt + Water Pump
