Fan speeds 1 and 2 not working
Old 09-14-2015
jeffsasse's Avatar
jeffsasse is an unknown quantity at this point
1997 Civic EX
The switch to change the heating/cooling fan only works on speeds 3 and 4. 1 and 2 are not blowing any air. They still show as on, as the lights still turn on. Anyone have a fix for this?
Thanks!
jeffsasse is offline
Old 09-14-2015
Stock 99's Avatar
Re: Fan speeds 1 and 2 not working
This happened to me as well. In my case the contacts on the back of the switch need to be sprayed with electrical contact cleaner. PIA to remove everything to get to them but it worked and 5 years later it's still working.
Stock 99 is offline
Old 09-14-2015
jeffsasse's Avatar
Great, I'll give it a try once I'm ready to change the lighting in the panel and let the thread know. Thank you!
Old 09-14-2015
If its not the switch, you can ohm test the resistor set.
ezone is offline
Old 09-15-2015
EdGasket's Avatar
EdGasket is an unknown quantity at this point
On mine it was the resistor pack which sits in the air ducting behind the glove box (at least on rhd models in the UK). Mine only worked on the top two speeds before I replaced the resistor pack. The resistor pack is peanuts on ebay especially a HK or China sourced one like I got.
There's Youtube video of replacing it.
EdGasket is offline
Old 09-15-2015
jeffsasse's Avatar
That's exactly what mines doing... Top 2 speeds only. That looks like the easiest and cheapest option so I will probably try that first
Old 09-25-2015
jeffsasse's Avatar
it worked! It all off about 5 minutes to replace the resistor and now all fan speeds work! Quick, easy, and cheap!
EBay item:
New Heater Blower Motor Resistor Fit For Honda Civic 79330SR3A01 JA1258
Bruce.Ringler
06-18-2015 08:12 AM
ORskier
05-03-2015 12:54 PM
GH04si
04-15-2015 08:13 PM
dooner24
04-14-2015 07:51 PM
supercivic01
South
11-30-2001 11:27 AM
Quick Reply: Fan speeds 1 and 2 not working
