Manual Shifter Sloppy 2000 Civci SI
Rep Power: 0 Manual Shifter Sloppy 2000 Civci SI
The shifter on my sons car moves all over the place, especially side to side. It does go into gear but it's just too much movement. The linkage at the transmission is tight and at the shifter. There is a rod off the end of the linkage connection point that looks like it would fit into a bracket that would limit the side to side movement and still move front to back. I haven't found any drawings that show any type of bracket. Any ideas??? Bob
Re: Manual Shifter Sloppy 2000 Civci SI
I'm used to seeing the bushings worn at the bottom of the shift lever, but anything could happen.
I guess you'll have to get under the car and have someone wiggle the shift lever so you can see where the sloppiness originates.
Rep Power: 0 Re: Manual Shifter Sloppy 2000 Civci SI
Thanks Ezone, I checked your drawing a little closer, put on my glasses and found that part 7 is missing. I did shim the bolt that connects the linkage to the shifter and that helped some. Thanks for the help. Bob
jtdunn4life
10-27-2015 03:33 AM
alxz310
07-30-2015 12:18 PM
