Transmission will not go into gear
Rep Power: 0 Transmission will not go into gear
The AT will not go into gear unless I reset the PCM (either by battery disconnect/fuse removal-reinsert-or OBD scanner tool).
Once I reset the PCM is will go into gear, drive for a bit and then it needs to be reset again. when I say a bit it could be 500 feet or 1/4 mile. Any recommendations? There are no error codes.
Rep Power: 0 Re: Transmission will not go into gear
Yes, once it is reset it will shift through all gears. However, as it heats up the time of failure shortens. If it is cold/cool, all conditions seem normal.
Update: No codes register when it fails. Unplugged speed sensor, got P720 error, so I guess PCM works.
Tested car on jackstands. Right wheel turns but left does not.
Tried to get it moving but is would not continue to turn (1 spin = 1 turn, no momentum)
Tested solenoids Ohms/operation satisfactory
-Shift solenoid A&B OK
-linear solenoid OK
- Lock up Solenoid A&B OK
screens clear
-linear solenoid OK
screens clear
Bounddyy
19
07-20-2015 02:42 PM
06Si_Girl
07-12-2015 12:08 PM
07-12-2015 11:54 AM
