Sponsored by:
Sponsored by: DashLynx
Brake Fluid Volumes Flushed from Each Line
Old 08-03-2015
honda.lioness's Avatar
honda.lioness is a jewel in the roughhonda.lioness is a jewel in the roughhonda.lioness is a jewel in the rough
I am flushing my 2003 Civic LX Coupe's brake lines soon. I am ready to use most of the 32 oz. bottle of brake fluid I bought. I estimate the volumes from the prop valve to each wheel, et cetera as follows:
Front Dr = 0.2 oz
Front Pass = 0.4 oz
Rear Pass = 1 oz
Rear Dr = 0.7 oz
Master Cylinder = 1.6 oz
Reservoir = 4 oz
It's been 4.5 years since the last brake flush. Still what is in the reservoir looks clear. I doubt I will be able to tell when old fluid is out of each line and new fluid has filled the line. I use a MityVac hand pump to do brake line flushes. The little cup attaching to the pump holds about 4 oz (precariously) before it has to be emptied.
Does it make sense to flush different amounts from each line? I was figuring on flushing only 2 oz (= 1/4 cup) through the front dr brake line and 4 oz, 10 oz and 7 oz, give or take, on the remaining brake lines in order.
TIA
Last edited by honda.lioness; 08-06-2015 at 12:00 PM. Reason: Wrong number of years since last brake flush given.
honda.lioness is offline
Old 08-03-2015
honda200192's Avatar
honda200192 is an unknown quantity at this point
Re: Brake Fluid Volumes Flushed from Each Line
Your driver side will be the less amount. Next would be passager side then the rear. You should be able to tell when the old fluid comes out. It might look clear but it will be a bit darker then the new fluid. So to answer your question.. Just flush each line until you see the clear fluid.
honda200192 is offline
Old 08-03-2015
Front Dr = 0.2 oz
Front Pass = 0.4 oz
Rear Pass = 1 oz
Rear Dr = 0.7 oz
Reservoir = 4 oz
I think you did not take into account the internal fluid volume of each caliper and/or wheel cylinder....and each caliper can be a large variable depending on the amount of pad wear and piston extension.
Reality: This is overthinking it.
I'd say to just suck out as much fluid from the reservoir as possible, then refill it with fresh fluid.
Then start bleeding at each wheel, bleed until fresh clear fluid comes out, plus a bit more for good measure.
If you want a measurement at each bleeder and you have a 32oz bottle of new DOT3 fluid (less filling the reservoir), go for 4-6oz per wheel, at least that would ensure each is caliper or wheel cylinder is operating in new fresh fluid.
HTH
ezone is offline
Old 08-04-2015
Thank you, honda200192 and ezone. All you posted sounds good.
Old 08-06-2015
I flushed the system yesterday. The old fluid was a bit darker but still clear. It was hard to tell when the new fluid was coming through the lines. But I think this says more about how clean my system is and I should not tarry over it. I imagine living in the dry Southwest as I do helps minimize absorption of moisture and so contamination. Hiccups yesterday: I had not flushed the system since Dec 2010, so I found both my turkey baster (for taking old fluid out of the reservoir) and Mityvac hand pump had failed, due to the residual brake fluid I left in them destroying rubber seals etc. On the spot I made up a little one-person bleed system with the proverbial small plastic bottle and tubing (see youtube and many other sites for this). I am delighted 3/16-inch ID, 5/16-inch OD tubing fits easily and snugly over both the front and rear bleeder valves. I bought my tubing at Ace Hardware "by the foot." Lowe's has it in a roll as well.
Misfit2613
Brakes
26
09-01-2018 05:02 PM
RIPSAW
11-06-2015 04:36 AM
lilrob1213
37
06-29-2015 06:45 PM
bsmiley
04-27-2015 01:27 PM
civicdude
Brakes
11-21-2001 08:00 PM
Quick Reply: Brake Fluid Volumes Flushed from Each Line
