Sponsored by:
Sponsored by: DashLynx
A/C refrigerant pouring/hissing out from/near compressor.
Old 06-16-2015
Dave88LX's Avatar
Dave88LX is an unknown quantity at this point
I have a 2005 Civic Hybrid with 130K miles. A/C worked fine 2 years ago. Last year didn't work. Dinky can-gauge said to add some freon so I did. It immediately leaked out somewhere down near the compressor. I don't know if it's a tube/connection, the compressor itself, if there's a relief valve, or something else.
Has anyone heard of this before and is there a common issue I should know about? If I need a new compressor, what is a good reliable known source?
If I need a new compressor, how do you collect the old refrigerant? I've heard of vacuum pumps, but don't know if that collects it. Don't know if a shop needs to collect it. I'm going to buy a real set of gauges as well. My truck A/C is shot so I'd like to learn this myself.
I know I will need to replace a couple other things while I have the system open. The cabin filters have already been done. I will be reading through this and looking for system diagrams to get a better handle on everything. http://www.autoacsystems.com/_faqs/d...ompressor.html
Thank you.
Dave88LX is offline
Old 06-16-2015
arokz89's Avatar
arokz89 is an unknown quantity at this point
Re: A/C refrigerant pouring/hissing out from/near compressor.
first of all your going to need to add vaccum to the system and check to see if the AC system holds. if it doesn't, then you must have a Freon LEAK, once leak is fixed you may add freon and check the system, but to do all this u must have an AC machine to propely Recover and Charge the System. NEVER use those do it your self kits they sell at oreilly or autozone. your polluting the system with their chemicals and isn't really good for the AC system
arokz89 is offline
Old 06-16-2015
There is none left to 'collect'.
ezone is offline
Old 06-16-2015
alex_nyc's Avatar
alex_nyc is an unknown quantity at this point
you need to find the leak! is it the compressor or a hose ect!
at 130k, you might need a compressor Assembly/kit!
with a leak like that for a long period of time (neglected), its hard to say if that AC system will ever work again!
alex_nyc is offline
Old 06-16-2015
Dave88LX's Avatar
Yep, figured that part out today. I'm shopping for decent gauges and vacuum pump right now.
Does the fast leak near the compressor sound like anything common you've seen?
Dave88LX is offline
Old 06-16-2015
Dave88LX's Avatar
Yeah I'm expecting the worst. Wasn't sure if there was some sort of pressure relief valve that may be getting tripped for some reason that could be looked into.
Oh come on, with enough parts, anything will work. . My commute is 140 miles r/t...It WILL get fixed!
Dave88LX is offline
Old 06-16-2015
Nothing routine, if that's what you were expecting.
Should be easy to find though.
ezone is offline
Old 06-17-2015
alex_nyc's Avatar
at this point you dont need gauges! you need to find the leak!
So just connect some Freon to the system and carefully look around without freezing your eyeballs!
after you fix the leak, you might want to change the Receiver-Drier (NOT Evaporator canister).
alex_nyc is offline
Old 06-17-2015
Evaporator canister.
You mean the Receiver-Drier.
ezone is offline
Old 06-17-2015
Dave88LX's Avatar
OK. I know the leak is somewhere down near the compressor. I'll have to get closer to it so I can figure out EXACTLY what it's coming out of down there.
Dave88LX is offline
Old 06-18-2015
alex_nyc's Avatar
be careful! looking up at dripping freon is not cool!
alex_nyc is offline
Old 06-18-2015
It could be..... *puts on sunglasses*..... super cool!
ezone is offline
Old 06-19-2015
Dave88LX's Avatar
Oh yeahhhhhh
I went to go put some freon in yesterday so I could find the leak; couldn't find the can I had with the hose ANYWHERE. I have 9 little cans that require a separate hose. I sold the two hoses I had at the yard sale. Figures.
I'll have to pick up a can today.
Dave88LX is offline
Old 06-02-2016
Dave88LX's Avatar
1 year later. Time to give this another shot.
Dave88LX is offline
h4ldol
04-24-2017 08:16 PM
jtcavey
09-30-2015 02:18 PM
JMKendrick
09-16-2015 06:17 PM
MichaelLW
09-14-2015 07:15 AM
JJ291
09-02-2015 11:49 PM
Quick Reply: A/C refrigerant pouring/hissing out from/near compressor.
