In Need of AC help....an AC expert of sorts
Rep Power: 0 In Need of AC help....an AC expert of sorts
Ok I own a 2001 honda civic lx 4 door, I noticed the ac was warm..so i charged it. lasted a couple days so i bought a can of ac die/refridgerant. noticed i had a leak from the condensor so i replaced it..lasted 3 days, so i bought another can of die/refridgerant..noticed the discharge hose( hose that connects to top of condensor and outside port of ac compressor) was leaking where the rubber met the aluminum. bought one from honda replaced it. air lasted a week then started blowing warm again. so i recharged it and only lasted a day so i then bought another can of ac die/refridgerant and i dont see the die coming out anywhere so im asuming it could be the evaporator core...but jesus what is causing it to continually to leak i am no ac expert, ive swapped many civic/accord camry motors..mechanically inclined and work on these in my spare time, but i cant figure out what is going on with this ac system how can it keep leaking did i do something to cause it? the cars ac didnt work when i got it not sure how long it was out, assume at least a year. can anyone shed some light here?
Re: In Need of AC help....an AC expert of sorts
All the dyes I see are UV Fluorescent....Get a good blacklight, park in a dark garage, and start looking.
Some of the blacklight dye tracing LED light kits come with yellow glasses to enhance visibility (because there aren't true UV wavelength LEDs, only near-UV), but if you use a TRUE UV light you shouldn't really need the yellow filter.
You could use soapy water and hose it down, look for bubbles.
You could use a freon sniffer (electronic leak detector).
solarpunk70
04-12-2016 11:43 AM
juicetayne
09-30-2015 11:02 AM
