Sponsored by:
Sponsored by: DashLynx
can I do this CAT?
Old 03-29-2012
Delightfully tacky. Yet unrefined
m3gach33zy's Avatar
m3gach33zy is an unknown quantity at this point
can I do this CAT?
So I have this DC header and downpipe installed:
http://db.tt/dwcOdQAY
When I get a CAT put in like this:
http://www.procivic.com/pages-produc...916/index.html
Will they just cut out the part I have circled in red and just attach it there to 1 and 2? Is that even a good idea? I have no clue what that mesh part is for anyways
m3gach33zy is offline
Old 03-29-2012
EM2ti
maxtierney's Avatar
Re: can I do this CAT?
Do you have smog tests in Oregon? The mesh typically covers the ribbed flex pipe, which allows for inherent movement/vibrations of the exhaust piping. Typically, when a race header is installed, a cat isn't used.
maxtierney is offline
Old 03-30-2012
m3gach33zy's Avatar
I'm pretty sure we have to pass some kind of emission here in Oregon. I see how the flexing portion would be important, but that's if I were to have a lot of power coming through there right? Since the best I'd ever do to the civic is an N/A build I don't think I'll need to have the ribbed part, and just replace it with a CAT instead? I got the header and downpipe for basically nothing, so getting a cat welded in will be cheaper than getting a new setup. But i'm not sure if what I'm thinking is even possible lol
Old 04-04-2012
paulymcd7's Avatar
paulymcd7 is an unknown quantity at this point
on a 4-2-1 setup like you have it would be hard to do but yes. the last 02 sensor is right after the stock cat idk if you have the 2 in 1 header set up like i do where the cat is on the header. if you do have this 2 in 1 thing you have to find a way to to extend the O2 wires down to the end of the cat on that downpipe then put a rubber stopper in the O2 sensor hole on the headers
paulymcd7 is offline
nola000
Engine start problems
63
02-17-2023 09:18 PM
Luluharp
09-27-2015 11:56 AM
winanthony94
09-25-2015 09:05 AM
blizza
09-20-2015 04:09 PM
Hollywoodsnake
09-20-2015 12:58 PM
Quick Reply: can I do this CAT?
