Thinking I smell fish here...
Girls twist wrenches too...
Rep Power: 150 Thinking I smell fish here...
So I was perusing ebay for Mugen accessories, and came across a few of these "Mugen" steering wheels. I thought that for the cheap prices I might consider one. I know the whole airbag/safety/etc. argument about them, and I am not going to have an airbag free wheel until I have a 4 point harness inside my car (the Schroth that's DOT approved). I believe in safety, but I think a 4 point harness would be better in a crash than an airbag. Plus, I'm not completely sold on airbags being beneficial. But that's a whole different can of worms here.
ANYWAYS... curious if anyone has seen this particular one http://www.ebay.com/itm/JDM-HONDA-MUGEN-POWER-320MM-STEERING-WHEEL-HORN-HORN-BUTTON-W-HUB-ADAPTER-/230746297905?pt=Motors_Car_Truck_Parts_Accessories &fits=Year%3A2002|Make%3AHonda|Model%3ACivic|Submo del%3AEX&hash=item35b98d1631&vxp=mtr
I'm about 99.9999999999999% sure this is a fake, but I personally don't care about that. Anyone know if this will mount up without much of a hassle? Or, do you know someone who's bought one of these knock offs and not had a good experience overall? Just is a style of steering wheel I like, and can't complain about the pric. However, I'm thinking there's some sort of problem with it (mounting, or some sort of functionality) since it is so cheap. Suggestions?
Live for the Twisties
Rep Power: 261 Re: Thinking I smell fish here...
That's fake.
4 point harnesses also aren't overly safe when used alone, it's really important that they be paired with a good quality racing seat. You might (probably) already know that, but just to add.
Rep Power: 150 Re: Thinking I smell fish here...
I do know it's better to use it with a racing seat, for safety reasons. However, from what I've seen in crash test results, using the Schroth with a stock seat seems to be performing even better than your stock 2 point belt. Correct me if I'm wrong though, as I am no expert on safety belts/harnesses. I would buy the harness first, as I'd prefer to use a 4 point on the road than a 2 point. But, I would buy a proper racing seat soon after as the harness would perform better with it. Just my own personal preference, as I do mostly freeway driving (and most crash tests are based around in-town speeds). Just a way for me to feel safer while driving, regardless of how fast my car is
If you're going to go fake, make sure the spokes on the wheel are big, and have some sort of convex shape to them to disperse any stresses over the whole thing. My wheel is an NRG which I bought used for $85. It's got a bit of flex to it if you reef on it, but because of its shape, it not going to bend that easily. Just don't go racing with a cheap wheel :P
So you're saying that a safety belt/harness does you zero good in a rollover crash unless you have a roll cage. Therefore; everyone needs a roll cage, regardless of what seat belt they wear. Makes perfect sense mate.
Rep Power: 210 Re: Thinking I smell fish here...
Airbags don't save lives, seatbelts do. The only reason for airbags is to "prevent" more injuries. I put the quotes in because in a 70mph wreck the airbag hurt me worse than the actual wreck did.
That I do know. However, it doesn't matter what restraint you use in a roll over, the roof is still weak. So... I don't see why a 4 point is more dangerous than a 2 point in that respect. Maybe a 2 point might let you go in that kind of crash, which MIGHT save you by ejecting you from the car, therefore not shearing your head off. But we all see the fault in that logic. Just the context doesn't make sense to me.
EM2ti
Rep Power: 270 Re: Thinking I smell fish here...
The other issue I understand that exists with using a four point harness stands in using it without a bucket seat, but this is far from something I am well versed in. A four point used in conjunction with a standard seat, which allows your body to move side to side, forward and back, can harm you because the belt itself has no give. Where in a bucket seat, that's a part of a complete safety system, the belt and seat work together to not allow you any movement. Imagine a side impact with a standard seat and four point harness, your body would shift to one side resulting in your neck hitting the strap of the belt HARD, that force is enough to inflict injury on a very sensitive spot.
I also feel compelled, although it's somewhat irrelevant to this discussion, that you would still be 18" short if you relied on a shiny blue Cusco cage.
The reason 4/5 Point Belts are more dangerous without a cage in a rollover is that you can't duck down or lean to the side in a rollover. In a two point, you have that ability. In a 4 point, your head and torso are stuck in the vertical position. You'll be about 18" shorter if you do survive.
Now, with the use of the Schroth harness and factory seats (not talking about any/all 4 points out there), does anyone know if it's actually a bad combination? I saw a DIY on how to install it on here or the 7th gen forums, but it was used with an aftermarket racing seat. Aside from that, I haven't seen much about them on the forums. Anyone know for a fact whether they are a good/bad combination? I remember seeing some information from (most likely) Schroth talking about the use with stock seats, but it was not manufacturer specific. I've never seen much for or against the use of these with the stock seats, or even about the use for daily driving. Anyone have actual experience, or at least a friend of a friend to say anything? Maybe some research they found? I've not found much besides people selling them, or manufacturer info that is very generic.
A bucket seat should fit like the name implies, like you're sitting in a bucket. Just a word of caution: If you do much driving at all a properly fit seat and harness will be uncomfortable as hell after a while. It's bearable when racing 'cause, well, you're racing. lol. The factory seats and seatbelts should be adequate to keep you're body in. If you're really worried about safety you should be worried about you're arms and head flailing about. I suppose that's where the airbags come in. I guess just keep you're thumbs in the wheel when the bags go off and your arms won't flail about.
I'm willing to sacrifice comfort for safety on my side of the car. I can't drive comfortably to begin with since I have muscle problems in my back as it is. I've rode in racing seats for a while before, and I don't have much a problem with them. I typically don't drive long stints anyways, and I am almost never awake to drive during rush hour (nor am I willing to work a job where I drive in that ungodly time). I'm fine with compromising comfort for safety. I just want to get rid of my airbag and use a harness because, as stated before, I don't like airbags. I don't want to be in a crash and have the airbag deploy. I sit too close to the wheel that it wouldn't be properly inflated when I make contact with it. Wish this wasn't the case, but I'm mostly torso not legs :/
Rep Power: 232 Re: Thinking I smell fish here...
if you didn't know your stock seat is designed to give when enough pressure is added to it so in case of a roll over your seat will go back preventing your head from being squashed. now with a harness bar behind your seat thats impossible.so basically without a proper roll cage its just for looks and therefore rice. i have personal experience being in a roll over if i had been using a 4 point harness i would be dead rite now.
Maybe I should have clarified... The Schroth Rallye 4. I don't need a harness bar for this one, and that's one of the reasons I'm getting it. So, anyone have information on anything other than a rollover?
ahh well then the only problem i can see with that is losing a rear passenger seat when you use it but what's wrong with your stock seatbelt ???
As I've mentioned before, I'd like to be as safe as possible in my car. Not only am I primarily a freeway driver, but I also drive a bit faster than most people on the road. I'm not aggressive, but I drive my car pretty hard for the most part. Also, I live in Phoenix AZ, which the drivers here are just horrid.
Also, being that I'm a short person, I sit closer to an airbag. Therefore, I'm not a fan of airbags exploding in my face. It probably will not be fully inflated when I hit it, and I'm not willing to take the chance of being hit like a boxer's punch. I've had enough of that when I boxed lol. I would prefer a 4 point harness over a 3 point and airbag combo any day. I'd probably be hurt more by an airbag with my stature, than if it didn't go off.
EM2ti
It seems that you are pretty set on getting the 4 point, so more power to you. Here's my advice then. In order to make it work, and as safe as possible, you'll need to keep your seat as upright as possible - to maximize the lateral and thigh supports. The more lean you have in the Civic's stock seats, the more you will be sliding around within the restraints. This is not a good thing. I'd drive around in this position before you buy/install the belts, because this is how you will sitting everywhere you go - Old Asian Lady style. No gangsta lean. While practicing this, make sure you never lean forward more than 2", or you've voided the test run. Make sure you have everything within arms distance, cause you won't get to it, unless you unbuckle. I've been in 5 point harnesses before. It's tolerable on the track, focusing on the road or for short periods in town, but it gets old after a while. Definitely not the way I like to drive around every day. I like my freedom of movement. I'm not trying to discourage you, I'm just letting you know what to expect. Disarming the airbag and extinguishing the SRS light is another topic for later.
Glad you're giving me the heads up. I Will definitely try that. I typically don't have much of a lean in my seat, but I've straightened it a bit so it's practically up right. I usually don't move much in my car to begin with, but I'll keep note of it. The nice thing about the Schroth is it's side by side with your normal 3 point. So I can switch belts if needed.
Yeah, disarming the airbag is totally a whole different headache, but it's something I'll get to when I swap steering wheels.
CarStuff
12-06-2020 12:52 PM
671civicLX
06-13-2015 05:56 PM
jc33312
05-12-2015 03:17 PM
