Makeover Sneak Peek
EM2ti
Rep Power: 269 Makeover Sneak Peek
Finally got my car out of the shop yesterday afternoon. Countless issues and delays. Wanted to share a pic of the new look before I figure out where/when I can actually do a photoshoot. Still a little weird to me. Getting used to the paint scheme. Wow, HIDs are different. Still need to align. Thankfully, all of the electrics work, including the fogs.
That Dude with the Questions
Rep Power: 174 Re: Makeover Sneak Peek
1 Post
Rep Power: 328 Re: Makeover Sneak Peek
I spy with my eye...
Quad piston calipers. What kind are they? Wilwood?
And how/where did u get those fogs for the tsunami front?! Kyats the tsunami front as well and was going to do like a custom for retro
And nice retro
And nice retro
Originally Posted by tbohar
K20?
EM2ti
Rep Power: 269 Re: Makeover Sneak Peek
I did all the wiring for the OEM Fogs and HIDs. Glad I did be cause I was able to bundle the wires together hide the harnesses away, for a clean look. Painting isn't my thing. I just stick to what I know, engines, suspension and brakes (and a little electrical now - haha).
EM2ti
I used OEM 01-03 Foglights. Inverted the housings, for an almost perfect fit. I visualized it in my head - thankfully it worked out. Little trimming and tweaking. It almost looks like they came from Tsunami that way.
EM2ti
Not yet. My K20 is still in the build phase. Cams, pistons, port/polish, flywheel, clutch, Quaife LSD, etc. Trying to get 250HP (all motor - N/A) to the wheels. Want it all done before I drop it in. Saves me from trying to do it with the motor in the car. It'll be a while. My D17 is getting closer to the magic 150 hp. I'm happy for now.
1 Post
nice. but where's the rest of the tsunami kit? lol
and you MUSTTTTTTTTTTTTTTT show us pictures of ur brake setup.... i dont think ive ever seen a 6 piston brake caliper on a civic!!!!!!!
Live for the Twisties
Rep Power: 260 Re: Makeover Sneak Peek
6 piston calipers eh..
I'm curious about the rest of your brake set-up now; what master cylinder, proportioning valve, what brakes do you have in the rear?
EM2ti
Thanks ya'll! I thought I had posted pics of my brakes before. Maybe they're in my album (in my profile). I have a Wilwood Rear Floating Caliper in the rear with parking brake. Custom made e-brake cables. 12.19" rotors all around. Custom Earl's Braided Lines. Stock master cylinder for now. Brake pressure is a little softer than it should be, but I won't swap until I change pads/bleed brakes. It's a MF to bleed these calipers. There is NO WAY to bleed them manually. You need to suck the fluid with a pump in order to fill it to the top of the calipers. Going with a RSX-S Master, when I bleed them. I bought a EP3 4-Way Joint, but the stock EM2 proportioning valve is perfect for my set up. More rear bias to compensate for the massive clamping force of the fronts. I'll make sure to post some new pics of m brakes too.
I'll be interested to hear how the type-s MC works out for you with such large brakes, so few people are running very large brake set-ups in either the dc5 or 7G communities it's been difficult to find much info on when it's necessary to step up to a DC5-R MC.
1 Post
oooooooooo pretty
1 Post
have u tried speed bleeders? they work wonders. i have them on my bike (i have 6 piston mono blocks as well, just not as big as yours. lol)
EM2ti
I wanted to go with the speed bleeders but I didn't know which set to go with. Companies make them for make/model not brand names (Brembo, Wilwood, Project u, etc.). It was a guessing game. Compound that problem with the fact that Wilwood is an American Company that uses standard sized fittings vs. metric. Let the headaches begin... Haha.
Received 1,443 Likes
Rep Power: 338 Re: Makeover Sneak Peek
wooow! my cheap headlight and stock looking 02 does not even get on the toes of yours!
1 Post
i have russle speed bleeders...but most are the same. not too much quality difference.
they're pretty standard.
EM2ti
Soon. Still waiting on my SW388s to get in from Japan. Can't realistically track on 19s. There's a bunch of people at my job that track and/or autocross on the weekends. Both auto and motorcycles. I might end up doing most of my track time on a bike. More thrill, less expensive (theoretically, anyways). My landlord is an avid cafe bike racer too.
I'm loving your ride! Retros def complete the look and the way the fogs look in that bumper is unreal. I always liked the Tsunami full front and the way you made it come together gives it more of a OEM feel because of the custom fog light mounting that has been done. *SEXY* eagerly awaiting more pics!
EM2ti
I fully agree with u about the clean lines on the front bumper. I personally would never get a full body kit but I saw this front on another car (four door) and it stuck in my mind.
