I know I know, another tranny thread. READ THIS!
Rep Power: 0 I know I know, another tranny thread. READ THIS!
This may have already been covered in these forums, but here goes. I emailed a local trans. shop and they had this to say:
David,
1998-2005 Hondas, accros the board have massive transmission failure rate. Either the converter or 2nd gear clutches fail which lead to a complete failure most of the time because the filter cannot be changed without disassembling the trans and it gets plugged with clutch debris and then the trans fails. That leads to buying a used one-We NEVER reccomed buying used transmissions that have a high failure rate because you can expect the same. Typically a used unit it above $1200 dollars, and then when you add labor, new seals, fluid you ve hit $2000 or very close. We can completety remanufacture one for a very similar cost with a superior torque converter and all new updated solenoids. We remanufacture a honda every week, sometimes 2. The best thing to do is change the fluid every year for about $140.00 and just cross your fingers. Hondas have been great cars and it is unfortunate that they have this problem. Once they have been rebuilt , Ive never seen a repeat failure at least at our shop. Thanks for contacting us.
Does this sound like a reasonable estimation as far as remanufacturing a superior trans? Any input is helpful, as I am now waiting on the imminent destruction of my 02 Civc trans.
David,
Rep Power: 787 Re: I know I know, another tranny thread. READ THIS!
sounds like they know what theyre talking about at least. not sure about the rebuilds lasting tho, unless they are also replacing the clutches with a non honda upgrade. im seriously considering not even wasting my time with this auto and just do a k20 swap with manual trans. the cost for a new auto trans is in some places higher than the engine swap. ive got quates anywhere from $3-5k for a new or rebuilt trans. no way am i paying that just to have the same problem. thats how much the car is worth by itself lol.
Live for the Twisties
Rep Power: 260 Re: I know I know, another tranny thread. READ THIS!
The end product with a rebuilt trans can vary based on who you have do the work, its the poor quality rebuilds that fail extremely quickly. If I went that route I would only use a performance rebuild kit, since they have better quality clutches and have them install and external fluid filter. The only issue is trying to find the performance rebuild kits is almost impossible.
I would really only consider an auto-manual swap or a kswap with manual in my car, these transmissions are cursed.
mjdiaz89
06-21-2016 09:26 PM
0396
05-04-2016 07:14 AM
beeemerdude
07-23-2015 03:53 PM
