Sponsored by:
Sponsored by: DashLynx
2003 CIVIC 2DR EX 1.7L D17A2 Coolant Fan Stuck on
Old 06-12-2015
alex_nyc's Avatar
alex_nyc is an unknown quantity at this point
Hi everybody! So my 2003 CIVIC 2DR EX 1.7L D17A2 has the Coolant Fan Stuck on. (not the AC fan).
When I disconnect the coolant sensor (up by the thermostat) the fan turns off. Does this mean that the sensor is bad and that the relay is not causing the fan to stay on? (the engine has been off a while and never overheated)
edited
alex_nyc is offline
Old 06-12-2015
Re: 2003 CIVIC 4DR EX 1.7L D17A2 Coolant Fan Stuck on
When I disconnect the coolant sensor the fan turns off.
That would make me believe the sensor is stuck on.
ezone is offline
Old 06-12-2015
alex_nyc's Avatar
thank you! and at what temp does the fan turn on?
I can use an OBD2 Bluetooth tester and a temp gun on the housing to test this.
alex_nyc is offline
Old 06-12-2015
I have a diagram that shows it turns on the fans at 199*F.
The scanner should not be your bible on this one, the temp sensor it reads is temp of coolant exiting the engine (upper hose).
The fan switch senses the temp of coolant exiting the radiator (lower hose).
They can be quite different temperatures during normal use.
HTH
ezone is offline
Old 06-13-2015
alex_nyc's Avatar
HTH
I had disconnected the coolant sensor at the upper hose. Is there a sensor on the lower hose? Where is the sensor located that is possibly bad?
thanks
alex_nyc is offline
Old 06-13-2015
Originally Posted by alex_nyc
I had I disconnected the coolant sensor at the uper hose. Is there a sensor on the lower hose? Where is the sensor located that is possibly bad?
thanks
Don't overthink this just because I ramble about what's there LOL
It's the one you unplugged that got the fans to shut off.
If you were to study how the thermostat housing is constructed (plumbing of the water pathways) it contains inlets and outlets for both engine and radiator all in one unit. The smaller sensor on top measures engine temp for the computer to use (and would set a code if left unplugged), the sensor pointed toward the front senses the temp of water exiting the radiator and controls the fan.
ezone is offline
Old 06-13-2015
alex_nyc's Avatar
Ok Got it! Thanks!
alex_nyc is offline
Old 06-16-2015
alex_nyc's Avatar
Re: 2003 CIVIC 2DR EX 1.7L D17A2 Coolant Fan Stuck on
I replaced the defective coolant sensor with a new $6 pepboys one and now the fan comes on like it should. It also runs cooler as per the gauge indicator.
Thanks for your help!
alex_nyc is offline
Old 06-16-2015
$6 ??? I guess if it works more than a week you got your moneys worth LOL
ezone is offline
Poopies
04-20-2017 11:36 PM
usajags84
05-10-2015 08:11 AM
Ian SFBA
Interior DIY
04-25-2015 02:25 PM
smmahan
04-15-2015 08:17 PM
deus-ex
04-13-2015 12:29 PM
Quick Reply: 2003 CIVIC 2DR EX 1.7L D17A2 Coolant Fan Stuck on
