Sponsored by:
Sponsored by: DashLynx
'01 Civic LX auto Trans problem
Old 04-06-2014
Motox20's Avatar
Motox20 is an unknown quantity at this point
As I was driving the RPMs spiked as if I was in neutral, there was no noise or warning, just started revving up. Got it home and added some fluid after noticing it was low. Now when I start the car it engages most of the time, and will drive normally(sometimes with slippage), and sometimes just starts revving like in neutral again, when that happens all I have to do is turn it off and back on and it engages fine again. I have so little time with night classes and work, I've done some research and saw that 7th gen has Trans problems, but I know so little about transmission repair or troubleshooting. I can just swap it out no problem, or tear the engine down to the block without thinking about it, but transmissions are my Achilles heel...
Is there anything I can try before resorting to just swapping it out? Also if it comes to that do you know anywhere I can get get a decent used Trans for relatively cheap? I'm in Michigan, Metro Detroit area, if it makes a difference. Really all I need is to get it working well enough to use as a trade in for a lease, to cover most of the $ down needed. I was actually on my way to clean it out and go up to a few dealers to see what my options for a trade in where when this happened.....great timing huh?
Also one last thing if I could, I can't find my manual, how do I know what Trans I have, CVT or not I mean. The guy at the local auto parts store gave me fluid that says not to use in CVT. IIRC a CVT requires only Z1 fluid but non CVT can use Dexron III or equivalent. Any and all help is appreciated.
Motox20 is offline
Old 04-06-2014
mikey1's Avatar
Re: '01 Civic LX auto Trans problem
these auto transmissions are very sensitive to fluid, they only seem to like honda OEM ATF.....if you have put anything else in, you have made a huge mistake,
when is the last time you have the fluid changed?
mikey1 is offline
Old 04-06-2014
Prayer?
Crying?
Voodoo?
Transmission dance?
ezone is offline
Old 07-10-2017
mdyer88's Avatar
mdyer88 is an unknown quantity at this point
I have the same problem, just when I turn the car off and back on it is a toss up if it re engages again. My car was throwing a torque converter solenoid code also. I am wondering if I need to change the torque converter or what?
My car also has been overheating, an I read that could be because of the torque converter. If anyone knows anything I could do to fix it please help.
Also what could putting the wrong transmission fluid in it cause?
mdyer88 is offline
Old 07-12-2017
NDNV's Avatar
NDNV is a glorious beacon of lightNDNV is a glorious beacon of lightNDNV is a glorious beacon of lightNDNV is a glorious beacon of lightNDNV is a glorious beacon of lightNDNV is a glorious beacon of light
Sounds like you may have a transmission issue AND a head gasket issue. I hope you don't but if that was the case it would be too expensive to repair for the age of the vehicle.
NDNV is offline
Old 07-17-2017
babbshonda's Avatar
babbshonda has a spectacular aura aboutbabbshonda has a spectacular aura about
Originally Posted by ezone
Prayer?
Crying?
Voodoo?
Transmission dance?
babbshonda is offline
Old 07-17-2017
babbshonda's Avatar
Yes. You need to replace the torque converter. The torque converter fails in many of these and particles from the converter stop up the filter in the transmission, which in turn starves the trans from fluid.
Putting the wrong fluid could cause the clutches to slip. Only use OEM Honda Fluid and NEVER power flush. Drain and refill only.
The transmission has nothing to do with your car overheating. Most likely your headgasket is failing. Also a VERY COMMON issue with the d17's.
usajags84
05-10-2015 08:11 AM
tylerginevan
04-27-2015 12:29 PM
dragonsblood
04-27-2015 12:28 PM
C6GrandSport
04-25-2015 09:41 PM
dooner24
04-14-2015 07:51 PM
Quick Reply: '01 Civic LX auto Trans problem
