Add spoiler or just swap the trunks?
I am Epic
Rep Power: 0 Add spoiler or just swap the trunks?
Guy locally has spoiler, Im guessing its OEM but he cant say forsure.
1) Did 01 Civic EXs come with spoilers from factory?
He would sell to me for good price, a lot cheaper than online but im looking into installing it and it sounds like I need couple things that I dont think he has like harness and foam pads.
His spoiler is attached to the trunk and the trunk is off the car. When I go see it, if the trunk is in better shape than mine and is quicker and easier to just swap trunks then ill do that. Cause I dont have a drill and really would hate to have to go buy or rent one just for this.
What you guys think? Muirsy on here said he swapped trunks on his and it was just a couple bolts. Sounds like its a lot easier to swap trunks than adding a spoiler.
What does this harness look like so I know what to look for.
Re: Add spoiler or just swap the trunks?
As far as replacing the trunk, first it would depend on the condition of the two trunks. If one is significantly better that makes the choice easy. For me it would also depend on the color of the car. Some colors such as silver will never match so I would rather have only a spoiler mismatched instead of a trunk and spoiler. If you replace the trunk you will also have to align it so the seams are even and straight, not hard but can take time.
Are the springs included? If you add the weight of the spoiler to the trunk you need to change the springs to compensate for the additional weight. This will have to be done either way.
I am Epic
Rep Power: 0 Re: Add spoiler or just swap the trunks?
If you swap trunks, is it only two bolts to take it off and im guessing the 2 going to the trunk latch?
Good point about the colour matching. Even putting the new trunk next to my car and doing it by eye can be tough. Sometimes you may only notice it under certain light.
My trunk now is in really good shape, minor hair line scratches that i buffed most out but its not 10/10 perfect. Most of the scratches are around the trunk keyhole from the previous owners.
I am Epic
When you drill, you do have to drill 4 holes right through the trunk lid right? Man id be scared of cracking the paint.
I am Epic
Ah crap I dont know if I can swap trunks cause my trunk lid is sound deadened and no way im redoing all that. Even though i have my sub in my cabin now and always wondered if i could get away with a naked trunk lid and still maintain no rattle.
Yeah you easily can, all you have to do is loosen the bump stops at the corners of the trunk, i have 2 12's and no trunk lid rattle...and as for the drill i have an old one too (circa 1970) but its got enough torque to snap your wrists off haha
I am Epic
And what about the springs?
When i go see him, i just wanna know what to look for.
If you look at the outer edges of your trunk (underside, and in area where the spoiler mounts) you will see 2 round spots on each side. look for O x2 That is the area drilled out for spoiler. You will not get a template you know The harness is attached to spoiler and runs to the 3rd brake light under the back deck. Make sure you get the little plastic electrical coupler needed.
The springs are in trunk under the deck (2 that run side to side) and are a biatch to replace. Mine for my 05 are still in my garage.
Rep Power: 788 Re: Add spoiler or just swap the trunks?
spoiler is pretty useless. its very heavy, requires trunk shocks unless you like using two hands to open it, and doesnt do anything. the real ones have CIVIC letters on the bottom i believe. and the leds are very bright.
lol, almost no oem spoiler is actually functional. if anything, it worsens aerodynamics and causes mpg reduction (both from the aero and from the extra weight).
real oem is pretty heavy. i think at least 20 lbs. the aftermarkets are prolly more like 10 lbs because they are made from either abs or fiberglass, much lighter. but the leds suck on them. if i had to get one, i would go aftermarket and have it painted, then find a used oem and swap the leds over. you can prolly get away with the stock trunk bars rather than upgrading to shocks.
I am Epic
Plus a spoiler isnt going to do jack squat for making my car look better or newer. Nothing will help this outdated car. Im picky about keeping the weight down in my car, so spoiler will just ruin it, and never realized an extra 20lbs will kill your milage too.
I am Epic
brainwashedmc
07-27-2015 10:05 PM
