Sponsored by:
Sponsored by: DashLynx
new manifold spring bolts
Old 09-21-2011
lowlife9's Avatar
ok so two years ago when i installed my megen header and after market down pipe the kit did not come with spring bolts and my stock ones were rusted out. yesterday i got some new spring bolts i wondering if i install these if i could possibly get an exhaust leak because i notice the stock gasket is designed to flex at least thats how majestic describes the gasket. the one that came with the kit im uncertain it will hold up what do you think.
lowlife9 is offline
Old 09-21-2011
sl33pyriceboi's Avatar
Re: new manifold spring bolts
you shouldnt have any leaks. the spring bolts pretty pretty hard. you will be ok
sl33pyriceboi is offline
Old 09-21-2011
you can get away with reusing the bottom donut gasket since its a hard metal type (just make sure the header lines up properly or it is very easy to have a leak). the top one is a crush gasket and will leak if you use it again. but you should not need to touch the top of the header at all.
gearbox is offline
Old 09-21-2011
lowlife9's Avatar
i guess there's only one way to find out. hopefully this will alleviate some of the rattling against the subframe especially in the rain.
lowlife9 is offline
herbiej
22
08-23-2015 01:02 PM
bhollie
08-19-2015 01:07 PM
PierrePierre
08-12-2015 02:42 PM
Theshwartz35
07-17-2015 11:13 PM
Ccoop87
07-09-2015 03:26 PM
Quick Reply: new manifold spring bolts
