Sponsored by:
Sponsored by: DashLynx
Door Sill Removal Question
Old 07-01-2011
Neopinhead's Avatar
Neopinhead is an unknown quantity at this point
Question Door Sill Removal Question
Hey guys,
I need to pull the door sill off the driver's side of an '04 coupe and get to the lock cylinder for the gas door/trunk...can anyone gimme some pointers? Maybe some pics? Do i have to remove the B pillar cover?
Just got the car and im afraid to just start pulling on panels....really dont want to brake anything...
Neopinhead is offline
Old 07-01-2011
TDC2001civic's Avatar
TDC2001civic is an unknown quantity at this point
Re: Door Sill Removal Question
theyre typically held down by plastic clips on the underside so you have to gently pry up, if the other plastics overlap you'll have to make some clearance so you can pop the sil off without damaging it. by making clearance i mean just pry them away from body but don't take them totally out (this refers to the kick panel by your feet when you sit in driver seat, and the rear plastic section. Make sure you look that there is not screws in certain areas
TDC2001civic is offline
numbersguy
Electrical DIY
09-15-2018 11:24 PM
ImmortalEX
Detailing
78
09-04-2015 05:35 PM
h4ldol
06-03-2015 03:26 PM
MamaBear2015
05-18-2015 07:37 PM
werdnahall
05-17-2015 11:37 AM
Quick Reply: Door Sill Removal Question
