question about oil
Rep Power: 164 question about oil
i just got back from an oil change and there was smoke when i opened the hood after getting back home. i looked and it seems like they spill oil on the exhaust pipe and that was causing smoke.
i also noticed two other things, when i open the oil cap and look inside i can see the springs and everything. is that normal??
also when i tap the oil pan with my fingernails from underneath it sounds hollow, like there is nothing in there. on checking the dipstick it shows that there is oil. is that sound normal also?
any help is appreciated. thanks!
Rep Power: 232 Re: question about oil
everything is normal except you paying somebody to spill oil all over your engine do that ish yourself so you know it will get don't rite. also while your under there make sure they properly tightened the drain plug or over tightened.
1 Post
Rep Power: 328 Re: question about oil
did u check the dipstick while the engine was hot? running? cold?
my advise:
1. go back and yell at those people and demand them to clean it.
2. dont go back afterward.
3. learn to change ur oil. its pretty simple. actually, its as simple as it gets. you need a few basic tools (an initial investment, but it isnt even expensive)
but if u dont want to do it yourself, then go to a reputable mech. yelp.com is ur friend.'
on a side note, where did u get ur oil changed? PLEASE tell me you did go to jiffylube...
if you oil light is not on, then you are ok.
Rep Power: 164 Re: question about oil
when the engine cools, clean it off. you can spray some simplegreen on ur engine, cover ur battery and intake inlet, and clean all the oil off....that way it wont attract dirty, grime, and get crusted it.
yes, thats normal.
thats pretty subjective. what may sound hollow to you may not be to a person who knows what they are doing.
my advise:
yes, thats normal.
my advise:
there is no way in hell that ill go back. i opened the hood and there was smoke, i was seriously about to go and yell at them but i understand that thats what i get for trusting someone else with my car. it was express tire in black mountain...my parents always used to take their cars there so i assumed it would be fine for a one time thing.
btw, i have a mechanic that i go to for everything i cant do myself. alot of times he makes me do the work while he stands back and guides me, and then doesnt even charge labor. but again i didnt have time to go there since its kinda far from my house, (i go in the opposite direction for everywhere i go).
RIPSAW
11-06-2015 04:36 AM
Red_Chaos1
06-21-2015 01:12 AM
amrhamed
06-01-2015 08:08 AM
