Sponsored by:
Sponsored by: DashLynx
Halo Lights are SUPER DIM!
Old 06-17-2011
chrisbrown21's Avatar
chrisbrown21 is an unknown quantity at this point
Okay Sooo..
I bought some headlights for my 2005 Civic Ex, And they were from CarID, They are the halo ones with 1 halo ring and whatever else, but anyways.. I got them installed and all, but... They are very dim, is there a way to make them brighter? Or add more LEDs or anything too it?
Or can I get an HID kit and run it for my Halo Ring? Just wondering..
chrisbrown21 is offline
Old 06-17-2011
Re: Halo Lights are SUPER DIM!
not much you can do, its just the design. it uses a light pipe so even if you change the led with a brighter one by opening the headlights up, it will not get that much brighter. the leds it comes with will burn out in a few months anyway.
gearbox is offline
Old 06-17-2011
CivicChick2001
civicchick2001's Avatar
civicchick2001 is a name known to allcivicchick2001 is a name known to allcivicchick2001 is a name known to allcivicchick2001 is a name known to allcivicchick2001 is a name known to allcivicchick2001 is a name known to allcivicchick2001 is a name known to all
are the ones u got similar to these?
http://cgi.ebay.com/ebaymotors/01-03...Q5fAccessories
i wanted to get these kind, and i think thats the same ring ur talkin about, but these look like they have another light for the actual headlight..
but if these like the ones u got, i dunno if i'd get em bc of the dim problem.. ?
civicchick2001 is offline
Old 06-18-2011
the halo is just for fun, like an extra parking light. its not for anything useful. i had those lights before in black and i wired up my own 5mm white leds which were brighter but still only visible at night. there are two leds per ring, one on each side at the bottom pointing inside to light it up. the 5w parking light still overpowers it ofcourse. the only brighter alternative is cold cathode light rings but they are not very reliable and dont work well in cold weather.
gearbox is offline
Old 06-18-2011
CivicChick2001
question.. is there a way to wire it up to where when u turn ur "parking lights" on.. that just the halo comes on? i think it looks so sweet with just that ring lit up.. and then have the actual parking light come on with the headlight? cuz if so, that's exactly what i'd want. i just love how that looks. thanks for lettin me know about ^ that tho never knew that about em.
Old 06-18-2011
not exactly how you describe. if you want the halo on by itself, you can always install a separate switch just for them. the bmw halo system is far more advanced (and uses a halogen bulb in newer models) so there are decent upgrade led kits that do work and are super bright like the LUX kits. the brand new bmws already come with bright white led halos with hi power leds and a unique optic system to channel the light. they are bright enough to see during the day as drls.
gearbox is offline
Old 06-18-2011
SO basically I bought crappy lights? If the LED is going to die soon, then how do i replace that, and everyone else halo rings are bright but mine.. What the heck dude...
So there is absolutely nothing I can do to make these brighter??? Like at all? Cant add more LEDs or anything.. I like the ring,I Just want it brighter!
Old 06-18-2011
SpeedDownZone's Avatar
You can buy these http://www.theretrofitsource.com/pro...roducts_id=103 but you will have to open your headlight to swamp out. There's also a guy on there forums that supposedly make good ones any color you want. Gearbox might know what iam talking about. But apart from that, are the headlight giving good light? You could just retrofit a nice projector and add the halo rings. Just read the forums there is alot of info there.
SpeedDownZone is offline
Old 06-18-2011
But what size would i get?? I dunno the size of the halo ring on those lights heh.. And i would have to take it apart and remove the old rings? Would these newer ones mount in place of the ones i take off?
Old 06-18-2011
Yepp the light output is great!
Except the Rings >.<
Old 06-18-2011
Iam not sure what size but you should try to measure a get a in the ball park number. They sell so type of adhesive for them. Compare your light out put to this one http://www.hidplanet.com/forums/show...output-shots!!
Old 06-18-2011
you would have to open up the headlights and measure whats in there already. then use fishing line to secure the new rings since there are already a few holes behind the stock ring.
gearbox is offline
Old 06-19-2011
carowcliffe's Avatar
carowcliffe is an unknown quantity at this point
similar problem, one of my halo rings went out (of my 4) and I have replacement bulbs that they sent me, but I haven't the slightest clue how to put them in! will I have to bake the headlight unit? or what?
carowcliffe is offline
Old 06-19-2011
either oven bake or heat gun around the edges.
gearbox is offline
carid
06-05-2015 11:51 PM
MamaBear2015
05-27-2015 12:04 PM
civic_gt
04-19-2015 08:15 AM
SSMatey
04-13-2015 06:09 PM
CivicS
11-22-2001 10:51 AM
Quick Reply: Halo Lights are SUPER DIM!
