Sponsored by:
Sponsored by: DashLynx
A/C help on an 02 EX
Old 06-07-2011
eckoracer17's Avatar
eckoracer17 is an unknown quantity at this point
My a/c just stopped working one day so I messed around with it by jumping across the switches and such to see if any of them were bad which I am not sure if that will work on Honda's or not. Checked the line pressure with a cheap a/c repair kit from wonderful autozone which says its fine. The compressor does not run. Are there any common problems with the a/c systems?
I purchased this car used in 05 and has been great until about a year ago when I paid it off of course. A valve/valve guide is bad (using a ton of oil and has a misfire, 75psi in #4 cyl), SRS light came on, clutch makes the clicking noise (which always has), driver seat rocks, alternator went out, headlights fogged up. I leaned up against my car one day and dented the right rear quarter panel and it won't pop back out and stay and I am only 160 pounds so its not like I backed my fat *** into it . The quality of the car is lower than my expectations to say the least and I take great care of my cars especially for what they cost.
eckoracer17 is offline
Old 06-07-2011
sl33pyriceboi's Avatar
Re: A/C help on an 02 EX
did u check the fuse?
sl33pyriceboi is offline
Old 06-08-2011
That was the first thing I checked. I forgot to mention that.
h4ldol
04-24-2017 08:16 PM
jtcavey
09-30-2015 02:18 PM
JMKendrick
09-16-2015 06:17 PM
MichaelLW
09-14-2015 07:15 AM
andyandyy
08-04-2015 06:37 PM
Quick Reply: A/C help on an 02 EX
