rims
Rep Power: 0 rims
I have alloy wheels on my 01 civic ex, but the paint is starting to chip off. I want to paint it a new color. Can i do it myself? or do i need it professionally done? What would be the cost?
Low and slow!
1 Post
Rep Power: 191 Re: rims
You can do it your self for cheap. Its really easy I did it to mine. You can do it with your tires on them to. just get some sand paper and sand off the clear coat, then put index cards around the rim in the grooves. All you need after that is the primer paint, base paint and the clear coat.
Rep Power: 0 Re: rims
so all i need to do is wash, dry, and sandpaper the rims and then apply all the paint?
What's the point of the primer paint and clear coat?
I don't think i could afford to get them powder coated right now.
Rep Power: 233 Re: rims
anything made for metal will work fine i painted my winter steelies with some left over dupli-color engine enamal and they still look like i just painted them this is threw connecticut winters to granted i do wax them.
well i bought all the equipment and started to sand down my rims but i noticed that the coating is still on. Is it okay to start priming and painting with the old coating on the rims? or do i need to buy a remover and get rid of everything to make it clean.
1 Post
Rep Power: 206 Re: rims
the real work of doing any paint is all in the prep. the better you prep and get a good base to work from, the better your paint will look.
you should get everything completely off and nice and smooth before you do any priming. once its primed, some people like to gently go over it once more to make sure its nice and smooth, then apply the paint.
if its only another hour or two of work to get them ready to prime, its worth doing it because if you dont, they will **** you off everytime you look at them.
yeah i get what you mean about all the prep work. i think i have this whole thing ready.
1) Remove wheels and clean them with water and soap.
2) Dry the wheel and then scrub them with sandpaper (320)
3) Apply paint remover or acetone and dry it.
4) Apply a few coats of primer.
5) go over it again with sandpaper (600)
6) Apply a few coats of the base paint.
7) Go over it with sandpaper (1000)
8) Apply the clear coating a couple times.
9) repeat with other wheels.
Am i missing anything or doing anything wrong? please tell me.
Balkos
09-11-2015 11:39 PM
