Sponsored by:
Sponsored by: DashLynx
'02 Civic EX AT - which way should ATF dipstick arrow point?
Old 04-13-2014
TrustyAutos's Avatar
TrustyAutos is an unknown quantity at this point
The ATF dipstick was the old, original part that did not fit well.
Consequently a bit of ATF fluid would spill out (checked that ATF level is within tolerance).
I bought the superseded ATF dipstick and it fits much more snugly.
There's an arrow on the dipstick, and when I try to make it fit as snuggly as possible, it seems to fit the most securely when it points to 2 o'clock (reference: standing at front of vehicle, facing cabin, arrow points to 2 o'clock).
Is that correct?
Thank you!
TrustyAutos is offline
Old 04-13-2014
Re: '02 Civic EX AT - which way should ATF dipstick arrow point?
The hole is round, the seal is round. Place it in there however it's most convenient for you.
JMO
ezone is offline
Old 04-13-2014
Thank you ezone, I will orient it based on subjective tightness.
However, as a scientist I am still wondering, why stamp an arrow as a visual frame of reference if it is of no practical significance?
Old 04-13-2014
IIRC, the arrows (dipstick and brake res lid) are supposed to point directly forward.
Personally--- I don't think it matters much, because they are round.
Some transmissions use an alignment tab for the trans dipstick, but this is not one of them.
ezone is offline
Old 04-13-2014
In your owners manual, I don't think it specifically says anything about the arrow.
I looked at an 02 owners manual on page 220-221 and saw no mention of the arrow.
ezone is offline
Old 04-13-2014
Cool, thanks ezone, I will set them to point to the front!
[Also, I will note, based on your experiences, it probably doesn't matter though.]
Xuhme
21
08-07-2023 03:40 PM
Dorval Andre
General 7th Gen
28
07-21-2022 05:53 PM
civic_gt
04-19-2015 08:15 AM
Quick Reply: '02 Civic EX AT - which way should ATF dipstick arrow point?
