8th Gen 2006 - 2011.
Oil Change
Old 05-26-2014
itsfighter's Avatar
itsfighter is an unknown quantity at this point
Oil Change
Hi Guys,
I went to mr.tire to rotate tires and wheel balancing. By mistake they had oil change in my appointment and did a oil change. The manager mentioned it's the same oil as honda.
They used valvoline premium conventional 5w20. They didn't reset my oil percentage.
Do you think it should be OK to reset my oil percentage and wait until my next change is due or do I need to replace the oil from dealer sometime soom (may be ina week or two)? I think my reg honda dealer uses Mobil 1.
Thanks in advance. Appreciate your answers.
itsfighter is offline
Old 05-26-2014
Re: Oil Change
They changed the oil, reset your oil life.
What specs are on the oil bottle?
API SN at the very least?
I'd run it for the next 3-5k or whatever you usually do, then change it like normal.
I doubt your dealer uses Mobil-1 in everything (unless you ask for it specifically), that makes for low profit oil change.
JMO
ezone is offline
Old 05-26-2014
itsfighter's Avatar
Re: Oil Change
08 honda civic lx - 65k - They used 5w20 same as whats listed in the cap.
Old 05-26-2014
Prelude Owner
GolNat's Avatar
Re: Oil Change
That's good they used the proper oil.
I would just wait until your next oil change to replace it.
GolNat is offline
Old 06-11-2014
civicvtecvtec's Avatar
civicvtecvtec is an unknown quantity at this point
Re: Oil Change
rest it, and you saved 25 bucks
civicvtecvtec is offline
Old 06-15-2014
"Honda - tried, true & tested...!"
brags's Avatar
brags is an unknown quantity at this point
Re: Oil Change
oil changes on my civic are done only by me. why? eliminates any screw ups
left over by quick Lube oil change centeres , or shops. not putting anyone down just saying hey... when theres 10 cars outside a quick Lube bay waiting for there oil change, screw ups are going to ocure whether we like it or not. but again not all shops will screw up not at least the good ones anyway.
im currently using the NEW Pennzoil Platinum Pure Plus its the latest and
greatest oil because its derived from natural gas "1st of its kind" for any oil on the
market to have. its the next evolution of oil that's here today
from Pennzoil. the "base stock is derived from natural gas" is a much cleaner base stock resulting in a much cleaner synthetic oil to run in your engine. believe me its good stuff to run in your Civic.
brags is offline
mattdoc
03-14-2017 12:10 PM
gearbox
Electrical DIY
72
11-27-2015 08:13 PM
BootyDo
05-07-2015 04:46 PM
SoNiCcIvIc
03-11-2002 03:37 PM
AnotherDopeStyle
01-05-2002 03:10 PM
Quick Reply: Oil Change
