8th Gen 2006 - 2011.
Sound from rear suspension on bumps?
Old 04-15-2007
illustrious100's Avatar
illustrious100 is an unknown quantity at this point
I got an AT 06 Civic LX with 11k miles. Just bought it 3 months ago from a used car dealership. I just notice a substantial sound from the rear of the car when I get off bumps which sounds like "DUGGG" Anyone got some info about this?
illustrious100 is offline
Old 04-15-2007
Retired suspension supermod.
robbclark1's Avatar
Re: Sound from rear suspension on bumps?
Is it under warranty?
robbclark1 is offline
Old 04-15-2007
frotrk's Avatar
frotrk is an unknown quantity at this point
honda had some front and rear shock problems. pretty sure they will warranty it.
Clark
frotrk is offline
Old 04-15-2007
AmbulanceMonkee's Avatar
it's gotta be.
AmbulanceMonkee is offline
Old 09-06-2007
rick93684's Avatar
rick93684 is an unknown quantity at this point
yes same here i just bought a 2007 civic lx and i notice that noice, i called honda and they told me they are having problems with there rear
rick93684 is offline
Old 09-06-2007
Hyperion's Avatar
Hyperion is an unknown quantity at this point
If its a single thump or a rapid series of two thumps going over sharp raised pavement. It may be the side impact foam inside the right rear panel that tends to come loose on some cars. Also check the rear bumper (whats under the the cover) for anything loose or hitting. Strike the rear bumper with youre fist to see if you hear anything unusual. I had to stick window tar calk between the foam abd the metal bumper to get rid of my rear noise.
Hyperion is offline
Old 10-11-2007
scuderias's Avatar
scuderias is an unknown quantity at this point
Same problem here... I think it is a temperature dependant problem... could hear it last winter. by the time i decided to take it to the dealer and see what was the problem it was already spring and they couldn't find anything. and i did not hear it over the summer. winter is coming though, so it remains to be seen if it starts again...
scuderias is offline
Old 11-16-2007
fix it. took it to the local dealership and they found some fluids were leaking from the struts. changed it under warranty at no cost
edspyhill09
06-12-2016 02:45 PM
Jeffdp
08-05-2015 11:38 AM
MN-02-CivicEx
06-25-2015 08:32 PM
reqy
06-01-2015 07:05 AM
supercivic01
South
11-30-2001 11:27 AM
Quick Reply: Sound from rear suspension on bumps?
